2017 Prius 4 with 17” wheels and added fog lights help/gas mileage went down
Discussion in 'Gen 4 Prius Fuel Economy' started by startvlr, Apr 8, 2018.
  1. startvlr
    startvlr New Member
    Ashville
    Hi all. Any help here would be greatly appreciated. Purchased a 4. Ecause of the available options on the 4T. Purchased a set of oem 17”wheels and installed factory fog lights and my gas mileage went down. Would this be because of the bigger wheels? My car is basically a 4 T now as far as wheels and tires go. Don’t understand why. Does the 4T have a different set up electronic/battery/gearing etc than the 4? Any help would be appreciated.
    fileaudio likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,586
    near Brisbane, Australia
    Different tyres probably.
    Some reports show greater consumption by 17" wheels, whether it's weight or greater wind resistance. Plus the fog-lights could have changed the aerodynamics (and added a little weight).
    You can see that those foglamps would be hopeless in actual fog - they're shining upwards in the photo, even glaring the camera.
    It could also be that, with more of a sporty feel to the car that you're driving it a bit harder to enjoy the newfound sportiness.
  3. KV55
    KV55 Member
    126
    43
    Northamptonshire, UK
    Excel
    Will swapping the 15 inch wheel for the 17 inch make the odometer read 13% lower for the same fuel consumption?
  4. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    It will definitely make a difference, but it's impossible to quantify as so much depends on the routes weather and driving style to calculate.
  5. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    If the 15" wheels had a 25" outer circumference and the 17" wheels have a 24" circumference, the added weight and the wider tires will definity effect mpg's, and if the speedometer is reading a 2-5 mph difference because of a smaller overall circumfernce, the mpg's are also going to be a lower number.
    RCO likes this.
  6. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    These generalizations may not all apply.
    Rotating a heavier wheel/tire combo will consume HP, and therefore reduce MPG. Low Rolling Resistance tires are rarer in 17 inch sizes than 15 inch sizes. New tires will get reduced MPG for the first 5000 miles, even if they are the same make and model.
    If you drive mostly above 50MPH, the fog lights will not reduce MPG much, but at lower speeds the engine will run more frequently to make electricity.
    Somewhere in the depths of Priuschat, someone found the raw results of EPA testing for different trim levels one year, and the 17 inch wheels/tires were about 3 MPG less efficient.
    fileaudio and RCO like this.
  7. startvlr
    startvlr New Member
    Ashville
    Actually the fog lights are not pointing up. The picture doesn’t do the lights justice. They are an oem replacement light and are very bright. I was driving at night the other day and turned me FFDO all lights and left the fog lights on. I could have easily driven home with just the fog lights on.
  8. Mendel Leisk
    Mendel Leisk EGR Fanatic
    39,172
    Yes. Our 3rd gen 17" are real porkers compared to 15", something like 24 lbs vs 18 lbs. The fourth gen 17" are better in that regard, still fairly lightweight, but I'd suspect still a little heavier. Then the tires are heavier, and wider. Also, you have more weight further out, nearer the circumference.
    And the weight is "unsprung". You can research that; it's too much for my brain cells.
    All of these factors are at play to increase rolling intertia and resistance, resulting in maybe 3~5% drop in mpg. It's not terrible though.
    RCO likes this.
  9. startvlr
    startvlr New Member
    Ashville
    Thank you for replying. Just kind of disappointing that it dropped off like it did. I’d say about 4-5 mpg. Not a lot but enough to make me regret getting them. The car sure does look better though. Thanks again.
    J
    RCO and Mendel Leisk like this.
  10. Mendel Leisk
    39,172
    What are the new tires? Did I miss that?
  11. Drhyed
    Drhyed Junior Member
    2018 Prius
    There are several things coming into play, first fog lights on/off wont make any difference the draw of fog lights off the electrical system wont be noticeable outside of a testing environment. Next atmospherics (air temp, humidity, density and pressure altitude) can play a huge factor in fuel economy so if one week its 90 and humid and the next is 68 and low humidity will make a huge difference. So even if you run a month long "test" in April and another in July its not an apples to apples unless you are correcting to a standard (59 degrees and 29.92 inHg) as a engine continually varies fuel mixture based on many things. Next are you doing the MPG calculations your self or just letting the cars systems do it? I often get 1-3 mpg variance per fill up vs what the car says and at times even a little more but not often. And finally there are a million different variables on wheel and tire combos, just because you up on size doesnt mean the weight goes up, many 17" wheels are much lighter than 15" steel wheels and the actual circumference of both will be within 1-3% of each other, if you go to tirerack's web sight (cant post web address yet) they have several good tech articles on upsizing wheel/tire combos.
    RCO likes this.
  12. Me_
    Me_ Junior Member
    32
    MD, USA
    2018 Prius
    Three Touring
    same question here. a tire with a 200 tread wear will drag the fuel consummation down vs a 600 with low rolling friction as on my 4 gen 3t
