"E" blocks = how much distance?
Discussion in 'Prius c Main Forum' started by dubit, Apr 10, 2018.
  1. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    I know a thread HAS to exist somewhere here on PriusChat for this, but for the life of me I can't find it. Nor can I find much on the net regarding it. Maybe I'm looking for the wrong term...
    Just out of curiosity I was hoping to know just how far one of those "E" blocks that show up after braking would get me on say - a flat stretch of road without the ICE running?
    Is it 1/4 mile, 1/8 mile, more/less?
    51,256
    at what speed?
  3. Prodigyplace
    12,420
    11,683
    Central Virginia
    My 2017 Prius manual says 1 E is 30 Wh and up to 5 Es per bar. I think each bar is a minute. You need to know what the EV only consumption rate is for your car to calculate the distance/speed data you desire.
    I am not in my car right now but I thought the screen displaying the E had a legend telling you how much energy one represents. The Prius c may be different than my Gen 4 Prius.
  4. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    The speed I had in my head was 40mph, since that's typically a speed at which my C will shut the ICE off and go full electric.
    Yeah, I have no idea what the consumption rate would be. The display in the C does say 30wh.
  5. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    This is a largely academic question, as it very much depends on the grade of the road you're driving on. I've gone 5 miles without the ICE on a long gradual downgrade.
    Another way to answer your question is that if you use only regen to stop from 60, you'll have enough power to accelerate back to about 40. Or about 50% efficient.
    jerrymildred likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    It's impossible to know what distance that would be because it's impossible to predict your acceleration rate, climb or descent rate, speed, wind, water on the road, accessory load, cargo load, and other variables.
    However, if you know your average distance per kWh, you can calculate it based on the number of "E"s. At 30 Wh per "E," 33.3 of them would be one kWh. So, if you average, for example, 4 miles per kWh, one "E" would get you an average of about 0.12 miles. At an average of 4 miles per kWh. At 3 per kWh, it would be about 0.09 miles. But since, braking is generally followed by acceleration, what we regenerate is worth a lot less than 3 miles per kWh in forward propulsion.
