Dash still failing
Discussion in 'Gen 2 Prius Technical Discussion' started by Gus07, Apr 12, 2018.
  1. Gus07
    Gus07 New Member
    NY
    Hello. Just replaced my 12V battery and second time I turn the car on the dash / speedometer didn’t turn on. Super bummed hoped the battery would fix this. What’s next?
    52,024
    test the battery, sometimes they are bad. also, the battery connections are important, especially the negative to ground. if not, probably the combo meter.
    valde3, jerrymildred and SFO like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
  4. Gus07
    Gus07 New Member
    NY
    I’ll test and report back. Checking from the car it said 12.1V Thanks bisco.
  5. Erik Owens
    Erik Owens Member
    162
    59
    COMBO METER ECU. COMMON ISSUE.
  6. Gus07
    Gus07 New Member
    NY
    Yuck! That’s a long replacement. I’ll try it if I gotta!
  7. bisco
    52,024
    12.1 idead for a new battery, and low for an old one.
  8. Gus07
    Gus07 New Member
    NY
    What the????? Geezzzz rotten luck with this. I have some free time tomorrow I’ll have the shop I bought it at test it.
  9. bisco
    52,024
    sometimes they sit around for a bit, and should be charged before installing.
  10. Gus07
    Gus07 New Member
    NY
    After driving 20ish miles this morning it’s reading 13.9. But I’m stuck in my drive way because it won’t turn off... Does replacing the Combo meter fix this as well?
  11. Gus07
    Gus07 New Member
    NY
    Just pushed the power button and it decided to turn off. Happy Friday.
  12. Gus07
    Gus07 New Member
    NY
    This guy says it’s just a soldering job / replacing a bad capacitor. Is this all the repair guys do if I were to ship it out?
  13. Gus07
    Gus07 New Member
    NY
    Update: new Combo Meter was installed today. Took me 2-3 hours total while juggling my 5 yr old.
    Shout out to Matt at Texas Hybrid for the replacement board. Worked right away!
    Until next issue, take care all!
    Gus07
    m.wynn, bisco and jerrymildred like this.
  14. iduncan
    iduncan Junior Member
    Maui
    Yep. Replacing the capacitors is all it takes. All capacitors have a finite lifespan, especially aluminum SMD caps. Just replace all 3 while you are there. I've fixed a few of these, after I fixed my personal car last year. Of course de soldering the old caps without lifting a pad can be tricky without a hot air reflow machine. I use 2 soldering irons, one to heat each pad simultaneously. Then when the solder is molten & the cap is loose I flip it to the side with the irons. I clean up the pads with solder wick, & I use solder paste with flux to solder the new caps on. The combo meter mileage does not need to be reprogrammed when it goes back into the same car it came out of.
    I took the time to locate caps that are correct form factor, & rated for the longest lifespan at high temps I could find. They are rated to 3000 hours at 105C IIRC. The original caps were only rated for 1000 hours at 105C. Theoretically mine will last three times as long as original. Of course the less time the car spends parked in the sun, the longer the combo meter will last...
    #14 iduncan, Apr 25, 2018
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    You don’t unsolder SMD caps to remove them. That’s unnecessary heat on the pads. And flux is not necessary either.
    Just grab them with a needle nose and rock them back and forth a few times and the feet break off the cap.
    Takes about 3 seconds.
