thermostat location
Discussion in 'Gen 3 Prius Main Forum' started by franken1313, Apr 20, 2018.
  1. franken1313
    franken1313 Member
    216
    26
    US
    Where is the thermostat located?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    On the other side of the water pump;).
    Any reason you’ll be looking for the thermostat :whistle:?
    Keep us posted (y).
    m.wynn likes this.
  3. franken1313
    franken1313 Member
    216
    26
    US
    The car is overheatin & over heats when speeding up then seems to cool with the bypass. Also no heater
    Raytheeagle likes this.
  4. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Coolant level is stable? How many miles on your Prius? The coolant level isn’t low?
    m.wynn likes this.
  5. franken1313
    franken1313 Member
    216
    26
    US
    There's a lot of coolant being spit into the resorvoir through the bypass hose. Over than that I don't think it's circulating. I just changed the water pump as well. I'm thinking the thermostat is stuck closed?
  6. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    You got access to Techstream? Any dash lights illuminated?
    I just did our water pump and thermostat on our 2010. Did the thermostat at the same time as the coolant was drained.
    You might have to go back in.
    What prompted the water pump change for your Prius? I did ours as a preventative maintenance item as it was in service for almost 9 years and 176 k miles.
    Good luck and keep us posted.
  7. franken1313
    franken1313 Member
    216
    26
    US
    High temp light plus check engine light. The temp is way high when engine is on. Temp will get to 270f and slowly go back down to 190f when on electric. No techstream
  8. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    With that temp, I’d be worried about the head gasket.
    Where are you located in the expanse of the USA? Might be able to point you toward a good shop for help.
    Definitely worth pulling the thermostat off and checking it’s functionali though.
    m.wynn likes this.
  9. Mendel Leisk
    40,698
    Here's some info from Repair Manual.
    HeavyFooted3SGTE and Raytheeagle like this.
  10. ChapmanF
    17,488
    Trying to remember from when I changed my coolant ... I don't remember seeing any coolant even begin returning to the reservoir through the upper hose until it was warm enough to open the 'stat. So I'm not sure whether you'd be seeing that with the 'stat stuck closed. But I don't remember for sure.
    I wondered for a long time how a thermostat could even get stuck closed (nothing is ever really going to stop hot wax from expanding), but finally did find an answer: it has to be done in by severe overheating, originally caused by something else.
    So if you had severe overheating because of your old water pump, I guess it's plausible for the thermostat to have been taken with it.
    -Chap
  11. franken1313
    franken1313 Member
    216
    26
    US
    Changed the thermostat. Engine still over heats plus now the AC air is not cold
  12. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    What are the codes that are displayed on the dash?
    Did you check the old thermostat functionality?
  13. franken1313
    franken1313 Member
    216
    26
    US
    Check engine and temperature lights on dash. Am I suppose to see bubbles in the reservoir constantly?
  14. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Can you take a video?
    Bubbling in the reservoir is not normal as that means the coolant is boiling or there is still air in the system.
    Where are you located?
  15. franken1313
    franken1313 Member
    216
    26
    US
    Am I suppose to see bubbles like turbulence not boiling bubbles
  16. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I’ve not seen that on our 2010 with 177 k miles.
    I just recently swapped out the water pump and thermostat and have seen no difference in behavior.
    You’ll need a code reader to see what all the codes are.
    If you let us know what neck of the woods you are in, we might be able to direct you to a shop or someone with Techstream to help with troubleshooting.
  17. franken1313
    franken1313 Member
    216
    26
    US
    I will have techstream soon. Do you see small movement in your resovoir?
  18. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    The reservoir in a Gen3 is essentially an overflow tank, so there should be no movement.
    m.wynn likes this.
  19. franken1313
    franken1313 Member
    216
    26
    US
    Any thoughts on why I lost cold ac?
  20. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Nope. The codes being read will help guide the next steps;).
    I’d check all connections to ensure that they are all snug in the area as you were around the ac system when accessing the water pump.
    How many miles on your Prius? Any accidents in its past?
