Toyota AC Outlet Supply Accessory (Not charging cable)
Discussion in 'Prime Accessories and Modifications' started by bowang, Feb 17, 2017.
  1. bisco
    51,835
    no idea, should be in the service manual.
  2. Salamander_King
    Salamander_King Senior Member
    11,016
    8,946
    New England
    What was the verdict? I read through this thread after finding the accessory on OP found in Japanese Toyota Prius PHV website. This accessory is called "vehicle power connector" and is standard accessory that comes with Japanese Prius PHV. Even if it works on US Prime, I don't think I would pay $600+ for this, but maybe if I can find it much cheaper at Yahoo! Auction. But not if I have to mod US Prime mod to install an inverter.
  3. bisco
    51,835
    it doesn't work.:unsure:
    drysider and Salamander_King like this.
  4. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    In order to have 110v a/c, you will need, at they very least, an inverter. It seems unlikely that the battery's 200 volts is available at the charging plug, so plugging some kind of dongle in is not going to do anything. Since this is a Japan only accessory, they may do things differently over there.
  5. eluo
    eluo Member
    114
    71
    Commack, NY
  6. Salamander_King
    11,016
    8,946
    New England
    I think Japanese version of Prius Prime (or Prius PHV) is equipped with an inverter as standard.
  7. hill
    8,790
    presuming the pack is relatively full when a storm /earthquake, power poll vs auto collision etc happens, & your home is drawing a relatively small amount of power (fridge cycling, a few lights, a TV, modum, router - maybe averaging 1kW), what do you get .... maybe 3-4hrs of power? Well - better than candles ... or sittin' in the dark.
  8. bisco
    51,835
    that's it, with a full tank of gas?
  9. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Agreed, BUT...
    The highlighted section means that the factory 1500 inverter is a Modified Sine Wave unit.
    A modified sine wave inverter sucks at running modern devices like cell phone chargers, computer/tablet chargers, & virtually
    anything with a microchip. A *true* sine wave unit is needed to operate any of the above stated devices.
    Rob43
    Andyprius1 likes this.
  10. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    What does a modified Sine wave look like?
  11. hill
    8,790
    Imagine a perfectly curvy wave versus a wave that looks like continuing up & down staircases. There you go.
    #71 hill, Apr 21, 2018
    Andyprius1 and Rob43 like this.
  12. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    ^ Hill nailed it. (y)
    That *staircase* really screws with modern electronics, a lot of chargers won't even charge your device and the arrow
    pointer on a computers track pad will act crazy by darting everywhere when connected to modified sine wave.
    Rob43
  13. Andyprius1
    2,327
    859
    Cool CA
    That’s a crazy waveform. I’ll stick with my sawtooth.
  14. Suds
    Suds Member
    31
    31
    Wichita
    Did it work on the American Prius?
  15. Salamander_King
    11,016
    8,946
    New England
    You are not going to get his reply. He has not been here almost 6 years.
    bowang was last seen: Mar 30, 2017
    In any case, the adaptor does not work on the NA models of PP. It is only an optional gadget that works on Japanese models.
  16. ChapmanF
    18,056
    Crazier: you might be looking at the red waveform in that picture, but the typical "modified sine" inverter produces the blue one. It only switches between three levels: zero, +peak, zero again, −peak.
    It's cheap to build that inverter because it doesn't need to produce any intermediate voltage levels. It only switches off and on (with two polarities).
    If not for the time it spends sitting at zero between humps, it would be a true square wave.
    With any wave, there's more than one way you can measure it. For example, you can measure its peak height. Or you can measure its RMS value, telling you what DC voltage would do the same amount of work.
    For a true sine wave, the peak reading is the RMS reading times √2. So North American household outlets give you 60-cycle AC at 120 volts RMS, same as 170 volts peak. That's nominal, anyway: both the RMS and the peak voltages are given certain allowable ranges.
    Different wave shapes have different relationships between RMS and peak. The game a "modified sine" inverter has to play is to find a shape (by picking the right length of time to sit at zero between the humps) such that both its RMS and its peak values will squeak by in their allowable ranges (the high end of one range and the low end of the other). This StackExchange answer goes into how that's done:
    https://electronics.stackexchange.com/a/625091
    Now, if you've got a regular waveform that isn't a sine wave, Fourier expansion tells us it's mathematically ... a bunch of different sine waves added together. Waveforms with sharp corners, especially, are lots and lots of different sine waves. Of course, that isn't how the inverter produces it (it's just turning switches on and off), but that's what it's producing, anyway.
    If the goal is to just imitate one sine wave at 60 Hz, the "total harmonic distortion" just tells you how much of the output is in waves other than the one you want. For "modified sine" it's around 35%. That is, you think this inverter is giving you 120 volts of 60 Hz AC, but 35% of its output is on frequencies like 180 Hz, 300 Hz, and other higher ones, not 60 Hz at all.
  17. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    A true sine inverter does even less - it only switches between + and - (no zero). It just does it way faster using pulse-width-modulation. It looks like this:
    The big reason a true sine inverter is more expensive is that it has to turn that square wave into that sign wave using a *filter*. That filter is usually composed of L's and C's (inductors and capacitors) and those can actually be quite expensive.
  18. bisco
    51,835
    hopefully this is all moot, if the n/a version comes with outlet on gen 5.
  19. ChapmanF
    18,056
    I'd like to hope that, but then #69 kind of poured water on that hope, with the press release that suggested the earlier Gen 4 version (in the markets that have it) was only "modified sine".
    So unless they have upgraded that aspect for Gen 5, you may end up getting an outlet, but the kind you don't want.
    There are some choices in how it does the switching. Switching losses can be held down by holding one side of the H-bridge on through an entire half cycle and just diddling the other one off and on a bunch of times, then doing the same with the other transistor pair for the next half cycle.
    So the switching really is between + and zero (a bunch of times) and then between − and zero (a bunch more times).
    All those little kicks keep a current rolling through the big inductor, like this:
    ... and after filtering the output:
    Those pics (and more details) are in this thread:
    My install and review of the ConVerdant LFI30-220 3kVA Pure Sine Wave Inverter for Backup Power | PriusChat
  20. Lee Jay
    5,850
    4,036
    Yeah, if it's a 3-level system, or a 2-level system in a 3-phase configuration you will have a zero. In these cheap single-phase systems, that's not common.
