non-Toyota coolant flush
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by icyrius, Apr 22, 2018.
  1. icyrius
    icyrius Active Member
    238
    114
    Florida, USA
    2014 Prius v wagon
    Hello all,
    My gen 3 is at 110K miles and want to do a radiator/inverter coolant flush. The problem is that I got a quote from my local Toyota dealer for their Toyota Super Long antifreeze coolant at $28 per gallon. I can buy Zerex or Prestone Asian vehicle coolant at Advance Auto Parts for $14 a gallon.
    Would you recommend that I switch from the Toyota brand? Since I will also switch spark plugs and clean the EGR valve, it is beginning to add up for this major maintenance.
    Thanks!
    j12piprius likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Is this all maintenance you will be performing yourself or having someone else do?
    I’m not one for cutting fluid corners as you do the activity so infrequently. I just picked up 2 gallons from the local toyota dealer near us and the parts guy got me down to $24 per gallon which was cheaper than amazon:).
    I’d stick with the SLLC personally as I know it’s what it should be and for not much more;).
    Good luck with your maintenance project (y).
    Bay Stater and Mendel Leisk like this.
  3. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    I am doing it myself. Thanks for the advice.
    Bay Stater and Raytheeagle like this.
  4. Mendel Leisk
    41,260
    I would stick with the Toyota coolant, considering that a coolant change is infrequent, and for complete compatibility. About four years in with ours both reservoirs were down a bit so for top-up I've already bit the bullet and bought a gallon of the Toyota stuff
    #4 Mendel Leisk, Apr 22, 2018
  5. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    or buy the red toyota coolant and you get 2 gallons because you'd have to mix 50 50 with water
  6. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    And what is the difference between the two types I am showing below? The Toyota dealer had both and said I must buy the 50/50.
  7. Prodigyplace
    12,521
    11,742
    Central Virginia
    One says Super Long Life. The other just says Long Life.
    Since Toyota recommends Super Long Life coolant. why look for anything else? :confused:
  8. Mendel Leisk
    41,260
    Yeah, use the Super Long Life, as recommended in your Owner's Manual, page 501:
    Watch all the pertenant @NutzAboutBolts videos if you haven't already, they're all linked, in a thread in the 3rd gen maintenance section. Your's is the v, but still I'd think worth watching, probably very similar.
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Since (as been talked about on other threads) you cannot drain all the coolant out I sure would stick with the super long life coolant that's in the car now. Since it seems no matter what you do there is going to be a lot of the old coolant left it's not a good idea to mix things up.
    Bay Stater and Prodigyplace like this.
  10. Mendel Leisk
    41,260
    Someone disconnect one of the hoses on the exhaust coolant heating circuit. Another way to get more out.
    Bay Stater and paprius4030 like this.
  11. Patrick Wong
    18,200
    6,500
    Super Long Life Coolant has a 50K mile change interval after the factory fill is replaced.
    Long Life Coolant has a 30K mile change interval, and needs to be mixed with distilled water, hence 1 gallon of LLC becomes 2 gallons with addition of the water.
    icyrius and Prodigyplace like this.
