Poor Fuel Milage
Discussion in 'Gen 2 Prius Fuel Economy' started by Dbryant1732, Apr 9, 2018.
  1. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Many people have the problem reoccur within 6 months to a year, even with a longer warranty.
  2. MelonPrius
    MelonPrius Senior Member
    809
    504
    Las Vegas
    Please continue to update this forum on how the battery holds up. I'm rooting for successful stories about replacing a cell.
    BlackBetty likes this.
  3. douglasjre
    douglasjre Senior Member
    1,763
    616
    Orlando, FL
    Stop using "B" in heavy traffic. It keeps the ICE on....
  4. Prodigyplace
    11,696
    11,317
    Central Virginia
    Using B ispins the engine to reduce the battery charge due to regenerative braking. In heavy traffic traffic that needlessly reduces your fuel economy.
  5. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    BINGO!
    That's yer problem right there if I'm correctly interpreting the rate that it gains and loses bars on the display. That and using B mode in traffic. But the battery SOC going up and down quickly is the battery's harbinger of doom. I can see it going to 2 bars from full if you're just sitting with the A/C going for about 5 straight minutes, but w/o the AC or in more stop and go traffic, it should last longer.
    A Prolong grid charger will likely rejuvenate the battery quite a bit, but once you get a red triangle of death and a battery code, it's almost for sure too late. Someone with Prius experience should be able to evaluate its health.
    Raytheeagle likes this.
  6. Art 02
    Art 02 New Member
    Virginia
    Really good question.
