center cap for 2015 three....HELP!!
Discussion in 'Gen 3 Prius Main Forum' started by fgp, Apr 23, 2018.
  1. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    well i want to remove my wheelcovers and show the black wheels. i naively assumed that any center cap for 2010 or later center cap would work. so i ordered some . waited 2weeks and.....they are too big! what is the correct center cap for a 2015 with the 15 ' wheels....help!!!! and thanks so much
  2. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Any center cap for 2010- should work, but ebay sellers aren't rigorous about truth in advertising. I have some arriving Thursday for my wheels and can measure them then; I believe they're supposed to be 55mm.
  3. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    thanks so much. thats what i thought but....im wondering if i should get them from the dealer and what car should it be from? may a corolla?
  4. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    ps let me know how yours work out so i can order the same. thansk again
  5. Flyin2Low
    Flyin2Low New Member
    NC
    These are what I bought....fit perfectly on my 2014.
    fgp likes this.
  6. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    thanks. the funny thing is that most of the centers say they fit 2010-2014. i dont get the difference in the 2015 and i even ordered some for 2010- 2014. they were too big??????????
  7. BZzap!
    BZzap! Senior Member
    1,607
    878
    FYI: these caps do not just slide into the center hub hole, they have to be snapped into the center hub with a moderate tap with a rubber mallet. They have an interference fit so that they won’t fall out. Could this be your problem?
  8. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    maybe, but it seemed that they were too wide for even that. im hoping someone with 15" 2015 will tell me exactly which ones they are. i really do appreciate your thoughts, though.these would have taken a wallop and a have with a sledge hammer....
  9. Flyin2Low
    NC
    I guess we can't post links? I provided a link to the product I bought on Amazon, I guess the moderators blocked it. Sorry.
  10. BZzap!
    1,607
    878
    Here you go:
    Toyota Prius 2015 1.8
    – Generation: III (XW30) [2009 .. 2016] " data-original-title="Hatchback " data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29);">
    – Market: USDM
    – Power: 134 hp | 100 kW | 136 PS kW - Kilowatts
    PS - Metric Horsepower " data-original-title="Power" data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29);">
    – Engine: I4, Hybrid
    – Center Bore: 54.1 mm center bore. It is measured in millimeters. Some factory wheels have a center bore that matches exactly with the hub to reduce vibration by keeping the wheel centered." a="" data-original-title="Center Bore" data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29);">
    – Wheel Fasteners: Lug nuts
    – Thread Size: M12 x 1.5 M12 x 1.25
    Nominal diameter (mm) x pitch (mm)
    UN-series Ex.: 9/16" - 18 UNF
    Thread size (in) - thread pitch
    UNF - Unified National Fine Thread
    See more details " data-original-title="Lug Size" data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29);">
    – Trim Production: [2009 .. 2015]
    Center bore is 54.1 mm
    SFO and fgp like this.
  11. Mendel Leisk
    41,804
    SFO likes this.
  12. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    cool. so the 55 mm cap is probably the one. the ones i got i think were 57!
  13. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    wow you guys are the best!!!
  14. Vman455
    539
    556
    The Middle
    Got mine today; OEM black caps, part number 42603-12780 "ornament sub-assembly."
  15. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    fits ok? pics??????AND thanks so much . ill try to order these. best place to do so? or...where did you order yours. very cool. my 2015 is very similar to yours. silver model 3
  16. kingman
    kingman New Member
    22
    kingman az
    #16 kingman, Apr 25, 2018
