Engine/Inverter Coolant Service Cost
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by PriusC_Commuter, Apr 24, 2018.
  1. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I'm creeping up on 100k miles for my 2012 Prius C and am noticed that the owners manual includes "Replace engine/inverter coolant" for this service. What's a reasonable cost for a dealership to charge for it? I might get the ATF replaced as well at the same time (did it at 40k miles).
  2. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    I'm not sure reasonable cost and dealership can be used in the same sentence;)
    But kidding aside, I paid $192.00 for engine and inverter coolant replacement last November at my dealer. I'm not sure how involved the inverter replacement might be, so can't really judge if it's reasonable, but it does seem a bit high.
    PriusC_Commuter and Mendel Leisk like this.
  3. Mendel Leisk
    41,921
    Watch @NutzAboutBolts videos (pinned at top of 3rd gen maintenance forum), he does both the engine and coolant changes. This'll give you an idea of the complexity, and even if you're not into DIY you'll appreciate how long it should take the dealership. I would guesstimate $100 plus cost of coolant.
    Note too: your (US) schedule says:
    But if you go to that footnote "3", there's this:
    Sneaky, but what it's saying, is that the engine coolant is to be changed at 100K miles or 10 years, but the inverter coolant you can leave till 150K miles or 15 years. Also, subsequent changes for both, are at 50K miles or 5 years.
    FWIW, the Canadian printed schedule make no distinction, says to change both at 160K km's (100K miles) or 10 years, and subsequent changes are per the US schedule. And just to confuse matters further, there's this sticker on the side of our inverter coolant reservoir:
  4. Mendel Leisk
    41,921
    For both, that seems pretty reasonable. I wonder if they would access and open the engine block drain? That would probably necessitate removal of the cowl (see @NutzAboutBolts spark plug video). Probably not, and by all reports, it's somewhat a waste of time, hardly anything drains?
  5. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    I totally missed that footnote since it's on the following page for the Prius C manual. I got quotes of $170 and $190, so I'll need to make sure they cover both the engine coolant and the inverter coolant. I wonder if I should just take it to my trusted local mechanic instead of a Toyota dealership for this one (I trust him more than the dealership service department).
  6. Mendel Leisk
    41,921
    Yeah verify. Also, you could postpone the inverter coolant change? Here's some info if you go with your mechanic:
    PriusC_Commuter likes this.
  7. PriusII&C
    PriusII&C Active Member
    429
    145
    San Jose, California
    Has some one changed coolant for Prius C? I only drained about 1 gallon coolant from my 2012 Prius C (including the radiator, the inverter, and the reservoir). I know that some coolant still remains in the engine block, but this is still way less than the total coolant capacity. Is this normal? How much did you drain from your Prius C?
