Engine over heating, should fan be on if engine is not?
Discussion in 'Gen 3 Prius Main Forum' started by franken1313, Apr 26, 2018.
  1. franken1313
    franken1313 Member
    216
    27
    US
    2010 Generation 3 engine overheating.
    Is the radiator fan suppose to be on if the car is overheated but is on electric with motor not running? The fan only comes on if the motor is running.
  2. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    Yes, the fan(s) will even run with a non-running cool engine if the a/c is on.
  3. franken1313
    franken1313 Member
    216
    27
    US
    Any thoughts why the fan only comes on if the engine is running?
  4. fotomoto
    5,638
    3,814
    So. Texas
    My guess is the fan control is defective or not getting the correct signal. A diagnostic tool would help isolate. Does the a/c activate it with a non-running ICE (engine)?
  5. franken1313
    franken1313 Member
    216
    27
    US
    No
  6. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I can imagine that because the engine is not running, there is no need for additional cooling (as the coolant temperature will not rise when the engine is not running). No idea if that is a strategy of the Prius.
    Out of curiosity: does the fan stop when the engine stops? I can not imagine the fan will come on when the engine is stopped because it would be strange that the coolant temperature rises when the engine is not running.
  7. franken1313
    franken1313 Member
    216
    27
    US
    Yes fan stops
  8. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    If you put on the ignition ON, does the fan also cones on? If it does, you got a problem with the fan relay or the wiring shorting with the ignition ON circuitry. That isn't supposed to be like that. You need to have that looked into, because it would with time, results into frequent fan motor replacements, and noise coming from the fan bearings itself.
  9. Mendel Leisk
    41,644
    What's telling you it's overheating: some OBD monitor? What temps are you seeing?
  10. franken1313
    franken1313 Member
    216
    27
    US
    Obd with torque app
  11. Mendel Leisk
    41,644
    Sorry, editted last post: what temps?
  12. Erik Owens
    Erik Owens Member
    162
    59
    if A/C is on they turn on. Normal ICE vehicles both fans come on if A/C is on to transmit more heat energy away from the condenser and radiator since it has to do twice the work to keep both systems cool. I would also look at Engine Temp and inverter temp. Quick check when vehicle is on remove cap from inverter coolant and check for flow. You will see "current" like in a slow moving river in the coolant. If you see nothing then inverter pump is out. Looks like someone has some puzzle pieces to figure out.
    Plus you have to account the Hot Water Storage Tank as well since the three way valve for that only works at certain times. Check those temps after a good 10 min drive to ensure your vehicle is not overheating killer. Keep it simple and stray away from electrical being your issue since if you start chasing too many issues, the only issue will be you.
  13. franken1313
    franken1313 Member
    216
    27
    US
    Generation 3
