What do you do about Headlights that are Old Yellow and Ugly?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 27, 2018.
  1. ski.dive
    ski.dive Active Member
    961
    242
    Hutchinson Island,FL. Mt. Snow,VT
    #1 ski.dive, Apr 27, 2018
  2. Rmay635703
    Rmay635703 Senior Member
    2,657
    1,679
    Somewhere in Wisconsin
    2013 Chevy Volt
    Sand them down then use a headlight repair kit with IV sealer
    srellim234 likes this.
  3. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    What would I do?
    I would use the search feature, either in PriusChat or the internet as a whole.
    My neighbor who has a gen2 with brand spanking new sparkly looking lens most likely went to the dealer and paid for such, though I never actually asked.
    I've read about all kinds of techniques, and even tried a couple.
    The one that impressed me with speed and ease of use was using Nevr-Dull. Did it make the lenses perfect again, no. Did it take more then a minute, no. Did I clean the residue off after cleaning, yes. Did it cause any damage to the plastic, maybe.
    The thread linked below isn't even 24 hrs old, there could be a gem hiding in there, or in many other threads on PriusChat o_O
    New Prius owner. | PriusChat
    jerrymildred and Raytheeagle like this.
  4. Henribayo
    Henribayo Junior Member
    TX
    I used Meguiar's Heavy Duty Headlight Restoration Kit. Took about 20 mins per headlight. The driver side was after, and the passenger side was before. 20180315_172703.jpg
    mikey_t and srellim234 like this.
  5. Stimp
    Stimp Member
    53
    North Carolina
    1. Remove them - lot's of instructionals out there, it's not terribly hard.
    2. Lightly wet sand them with 1500 grit to remove old protective coating (clearcoat/yellow stuff)
    3. Wet sand with 2000, sand with 2500 if you want too, but not necessary.
    4. Dry well and use paint prep to clean the plastic.
    5. Spray a quality clear coat and let it harden overnight.
    6. It will look really good at that point, but there may be imperfections/runs/dust in the clear coat. You can stop there if you want, but...You can also wet sand with 2000 or 2500 to clean it up.
    7. If you wet sanded the clear coat it will need to be polished. They will look really good at this point.
  6. ski.dive
    961
    242
    That's a lot of work and I heard sanding, etc. is only a temporary fix,
    then they turn yellow in a few of months again!!!
    New headlights on EBAY=
    Does anybody have these $100 EBAY headlights?
  7. Stimp
    Stimp Member
    53
    North Carolina
    Not if you use a quality clear coat.
    Rmay635703 and SFO like this.
  8. Stimp
    Stimp Member
    53
    North Carolina
    2004 model headlights after sand and clearcoat, before additional sanding and polishing.
    PGHtoolman and JohnLS like this.
  9. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    It doesn't restore them to crystal clear if they're really bad but I just use something like this from time to time to keep mine looking ok before they get that bad.
    Meguiar's Two-Step Headlight Restoration Kit | 1800834 | Pep Boys
    It's really not any different than washing and waxing a section of the car so I just do it as part of a car cleaning when I think it needs it.
  10. tada
    tada Member
    73
    77
    Tucson, AZ
    2002 Prius
  11. JohnnyCanuck
    JohnnyCanuck New Member
    Vancouver Island
    Four Touring
    Uses the sandpaper method. I suggest clean with isopropyl alcohol before you spray, 3 coats and allow 5-10 minutes between coats then leave over night. Use 2x spray, it has UV protection and anti-yellowing written right on the can. And you don’t need to remove at all. Use painters tape on outside edge when sanding and use garbage bags to cover car for any potential overspray when spraying.
    ukiltmybrutha likes this.
