Prius Hybrid Battery of San Jose, has anyone used/heard of it?
Discussion in 'Gen 2 Prius Main Forum' started by sli, Apr 26, 2018.
  1. sli
    sli Junior Member
    I heard about this place from a friend. The price for replacing the hybrid battery is really good. Has anyone heard of it or have experience using their service?
    TIA.
  2. Prodigyplace
    12,516
    11,739
    Central Virginia
    I would not recommend them or any company selling "repaired" or "remanufactured" battery pack.s. They repair them by replacing failed modules with used modules from other failed packs. Expect to replace again multiple times during their warranty period. Does the warranty cover installation? Many do not.
    If you are DIY you can get a kit of new cells from @2k1Toaster here for $1600 shipped, It has a 2 year warranty but should last much longer than that. Experts here quit reporting on their tests because it was to boringly good. One expert (@ericbecky ) used it for 3000 miles before loaning it to a customer. I believe it is still functioning like new.
    The link is in my signature.
  3. bisco
    51,787
    are you planning on keeping your car longer than the warranty?
  4. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    I have not seen their name mentioned here (ever) so no rep I can relate. How long do you intend to keep this car?
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,415
    3,286
    Madison, Wisconsin
    I would ask a lot of questions.
    But basically you are going to get what you pay for.
    If it is cheap (under $1000) it is a cheaply done job.
    The battery will consist of USED modules from different packs.
    They may not be matched to one another.
    They may not be balanced.
    If it is NEW it will be more expensive (around $2750?) but it will be 100% reliable and last a long time.
    If you choose to DIY you will save yourself the labor fee.
    This is important for used packs, since you will likely have to mess with a used battery multiple times.
    Raytheeagle likes this.
  6. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    #6 SFO, Apr 27, 2018
  7. ericbecky
    4,415
    3,286
    Madison, Wisconsin
    $650 for a battery.
    Clearly it is not new.
    It says "refurbished".
    The problem is that refurbished is a very squishy term.
    Some people open a pack, look at static voltage and simply replace the one module that looks bad, and then send the car on its way. Nothing more.
    I imagine that is what $650 buys you.
    But that will be just the beginning of your game of whack a mole. Plan on spending more over and over if you plan on keeping the car longer than the warranty period.
    Plus you get the added negativity of the possibility that the pack will fail at any time. Not good if you need your car to be reliable.
    Prodigyplace and Raytheeagle like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    SFO likes this.
  9. fotomoto
    5,632
    3,809
    So. Texas
    Hmm, sounds like a $650 pack is the "sell your car with a "new" battery and no trouble lights" option.:cautious: I'm seeing ads like this on my area CL; typically 1 yr warranty.
  10. bisco
    51,787
    o/p is probably having them install a battery as we type.
