2007 engine won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dave 2007, May 12, 2018.
  1. Dave 2007
    Dave 2007 New Member
    Salem
    i have a new 12v fully charged. Power button brings dash to life, orange triangle on the dash. Engine won't start. Moving shift lever only moves from park to neutral, won't go to D or R. Tried jumping with under hood contact point, no luck. Any ideas to try?
    51,790
    welcome!
    try reading the trouble codes. is the 'ready' light on? how many miles on her?
    Dave 2007 likes this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,415
    3,286
    Madison, Wisconsin
    Need a bit more details of how we got here.
    Is this a car you recently bought or do you know the history?
    Was there a recent oil change?
    Or any other recent work to the car?
    Was the car driven regularly before it died?
    For around $75 you can get some helpful diagnostic equipment
    - Android phone/tablet
    - elm 327 Bluetooth OBDII reader
    - torque pro app
    You can see hybrid battery info, read error codes, clear error codes, and more.
  4. Dave 2007
    Salem
    We bought this car new in 2006. Has 16
    169,000 miles. Only code is P0A80. Purchased new in 2006. Having some issues with this chat reply. Hope it goes through.
    we
    Purchased in 2006. 169,000 miles. Only code is P0A80.
  5. Dave 2007
    Salem
    oil change is due soon. No ready light only the red triangle of death.
  6. ericbecky
    4,415
    3,286
    Madison, Wisconsin
    What are you using to read the codes?
    I'm guessing there may be something else.
    Is the hybrid battery fan running loudly in the back?
    jerrymildred likes this.
  7. bisco
    51,790
    check the 12v health, just because it is new doesn't mean it is charged. and sometimes they are defective.
    make sure the battery connections are clean and tight, especially negative to body.
    in the end, you might need a hybrid battery.
  8. Dave 2007
    Salem
    No fan sound. Used Fixx code reader. Ready light blinks twice and there is clicking in the rear of the vehicle associated with the blinking.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    P0A80 is replace Hybrid battery Pack. The main big battery is toast.
    The engine is turned over by the Hybrid battery pack powering one of the electric motors in the trans.
    But it must not be a surprise though the mileage has probably tanked on you. Failed hybrid battery is getting to be the number one post in the G2 section.
    Theres hundreds of posts about that battery and what to do. Use the search forum button up top and search hybrid battery.
    #9 edthefox5, May 12, 2018
  10. ericbecky
    4,415
    3,286
    Madison, Wisconsin
    There is more info that your reader is not picking up.
    I'd want to see voltage data for 12v battery and the HV battery.
    Either need to take it somewhere or buy the under $75 worth of equipment I mentioned.
