long beep, red triangle, "problem", can't reach Ready mode
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mark010101, May 12, 2018.
  1. Patrick Wong
    18,210
    6,511
    You can use Techstream if you like. I like disconnecting the 12V battery to give all ECUs a fresh start upon power up.
    If P0A1D comes up again, find out the three digit info code associated with that and post.
  2. JC91006
    JC91006 Senior Member
    16,815
    8,596
    If your car has completed the recall, the pump should not get shorted again (unless it wasn't done during the recall). The fact that it did short again should be reported. The recall was suppose to fix this issue so you don't break down unexpectedly and put yourself in danger.
    There are occurrences where the pump fails but you are not stranded. But your situation left you stranded because everything shut down.
    SFO and Raytheeagle like this.
  3. mark010101
    mark010101 Mark 04, 05, 08 Prius Owner
    65
    31
    East Central Illinois
    Victory! Cleared codes, drove about 20 minutes, no new codes set. I will get an inverter pump on order and replace it. Thanks so much everyone for your fantastic help!!
  4. mark010101
    65
    31
    JC91006: Well that does make me wonder. Perhaps I was sold an old style pump at the time?
  5. Patrick Wong
    18,210
    6,511
    I don't think that there is any guarantee that the current pump design will not short.
    I posted in July 2009 about replacing the inverter coolant pump as a preventive measure, prior to the recall being announced.
    How to Replace the Inverter Coolant Pump | PriusChat
    There were no obvious differences between the 2004 model year original equipment pump and the replacement pump with respect to markings on the pump bodies.
    That post shows a photo of the part number associated with the new pump, which was G9020-47031. Looking at a Toyota dealer parts website today, I see that the current number is still G9020-47031 while the prior number had a suffix of 47030.
    Motor Assembly - Toyota (G9020-47031) | Discount Toy
    Hence it is not clear to me that there is any difference in inverter coolant pump design.
    #25 Patrick Wong, May 12, 2018
  6. mark010101
    65
    31
    I checked my records and I replaced the pumps in both of my Prius (Prii ?) at the time with the new style pump G9020-47031.
  7. mark010101
    65
    31
    Additional information: I replaced the failed '04 inverter coolant pump in Oct 2010 at 99.7K miles. Fast forward to May 2018 (~7.5 yrs later) and another failure of the coolant pump at 196.3K miles. So the life of these based on my two data points is about 98K miles.
    Raytheeagle likes this.
  8. JC91006
    16,815
    8,596
    98k miles is right on with the guesstimate we often recommend replacement. If you have 100k miles on the pump, change it out
  9. mark010101
    65
    31
    I have my inverter pump on order and it should be here by the end of the week. My son is still driving the car with the inverter pump unplugged (very short distances < 2 miles back and forth to school) until I can get the new one installed.
    Question/Observation: It seems to be a bad design idea to have the inverter pump on the same electrical circuit as the ECU. When the pump shorted and the fuse blew, it took the ECU out and the car was dead. If this had happened on an busy traffic situation, it could have been fatal. Thankfully it happened as my son was turning into a driveway in a residential neighborhood.
    Did Toyota ever change the electrical circuit design and put the inverter pump on another circuit for Gen 2? Hopefully they would have addressed this with Gen 3.
  10. JC91006
    16,815
    8,596
    This is why you have to report the problem to national highway safety administration
    SFO likes this.
  11. mark010101
    65
    31
    Pump arrived yesterday and I installed it today. The coolant around the pump smelled heavily of burnt electronics (you know the smell). I figured it was localized to around the pump at the time of failure and did not bother to flush and refill the system. Pump is humming and all is well (no error codes). Many thanks to everyone who chimed in and help diagnose the problem!
    Raytheeagle and jerrymildred like this.
  12. Scott Caputo
    Scott Caputo Junior Member
    Los Angeles
    Where exactly is the AM2 fuse? Thanks
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,080
    1,992
    NJ-USA
    It is in the underhood fuse box - black box on the left (driver's side) of the engine compartment.
    mark010101 likes this.
