My 2014 prius died today
Discussion in 'Gen 3 Prius Main Forum' started by pberardi, May 16, 2018.
  1. pberardi
    pberardi New Member
    california
    I took care of it as much as i could, really. Yeah maybe the first two years I drove 85 down the freeway but the last year or so I was easy on her. I never missed an oil change or a 30k maintenance. I did the plugs at 120k. Today I got the news at 198,205 miles. I noticed the sputtering about a week ago. When the car would sit for a little while upon starting up it would sputter. Today the check engine light went on. The code was P0301 cylinder misfire. I took her to my shop and they said that since the coolant was low, it was probably leaking into the cylinders which means a blown head gasket. It would cost $2800 to fix. I was still getting 42mpg sometimes more. I had the car for 47 months and two weeks. I am just looking for someone to feel sorry for me and tell me that it is all gonna be alright.
    amos and bisco like this.
  2. restcure
    restcure Junior Member
    Ontario, Canada
    2014 Prius v wagon
    Touring + Tech
    My general rule of thumb is that I'll repair a car until the cost of a single repair exceeds the value of the vehicle. If I were in your situation I'd be comparing a $2800 repair car to the cost of a comparable 2014 Prius.
    douglasjre likes this.
  3. Mendel Leisk
    41,791
    What's the fix, swapping in a replacement (used) engine, or replacing the gasket?
    $2800 seems reasonable, btw. I can drop that kind of money at my dentist, easy... :(
  4. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    More and more people these days are swapping in a used Prius engine.
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    Things to contemplate:
    1. Engine has almost 200,000 miles on it.
    2. $2800 is just an estimate. Figure in an extra 30% for unforeseen problems and incidentals.
    3. May have a cracked cylinder head. $$$
    4. Labor for diagnostic tear down May be money down the drain if it needs a replacement engine.
    5. Should you get a second opinion?
    6. Calculate cost of replacing engine with lower mileage, used engine.
    IMHO, it would be wiser to just replace the engine.
  6. MelonPrius
    839
    516
    Nevada
    pberardi, check this company, LKQ, out for a used replacement engine. I don't know where you are in California, but there's a decent chance they have a location close to you.
  7. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Doing some quick math, I assume you are the original owner. At 50,000 miles per year on average, this car doesn't owe you anything! Imagine how much gas you saved owning a Prius. Consider what else could go wrong with it, and at 200k miles, that's a long list. If it were me, I'd move on to the next one.
  8. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    Imagine if this was business use, and you were being reimbursed at the federal 54.5 cents per mile. I was happy enough to get to use my own car on a two week work trip one time, and took home $700+ for the use of my 1996 Subaru ($150-200 went to gas).
  9. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    You are doing what? 180 miles every work day? I would just buy a new/used car, it's apparently just a tool to make money... I hope.
  10. MikeV
    MikeV Junior Member
    95
    philadelphia
    what ended up happening. you said probably leaking into did mechanic sho you or make a video clip at least to show you.
