Digital Rear View Mirror Available in Japan (Not for Prime)
Discussion in 'Prime Accessories and Modifications' started by Tideland Prius, May 17, 2018.
  1. Tideland Prius
    16,597
    Not the cleanest of installation (see bottom centre photo of the camera mounted on the rear window) but it works and has a wider view and solves the rear spoiler visibility complains of some owners.
    This accessory won't work for the Prime as the camera is mounted in the rear window and needs a flat surface.
    #1 Tideland Prius, May 17, 2018
    toyopri808 and HPrimeAdvanced like this.
    52,263
    i would like one.(y)
  3. PCPrime
    PCPrime Member
    110
    103
    Tampa Florida
    The camera mount seems so big
  4. PCPrime
    PCPrime Member
    110
    103
    Tampa Florida
    I would love to have the camera integrated in the shark fin antenna
    Shaunius likes this.
  5. Insighter
    Insighter Active Member
    409
    287
    SoCal
    Is there a way to get this in the US? Do you know what it costs? I wonder what the buttons on it control, and if you keep the garage door opening functionality.
  6. Tideland Prius
    16,597
    I'm not sure. This website does carry JDM parts but he only has the standard set. Maybe check to see if he'll add it later?
    All Products
    I only know that the switch that looks like the manual mirror flip switch is the On/Off switch to toggle between mirror and digital display. I can only speculate that the 3 buttons are Homelink buttons.
  7. Insighter
    409
    287
    SoCal
    Okay, thanks. I noticed that the rear-window defogger lines pattern is substantially different in the photo that shows the camera for this setup. That window isn't curved, either. Do you think this is meant for the Prime? The defogger pattern on our rear windows is really odd.
  8. Tideland Prius
    16,597
    Ahh good catch. I saw it on the Gen 4 accessory. Maybe it's not available on Prime due to the rear window curvature. Let me check.
  9. Insighter
    409
    287
    SoCal
    Okay, thanks. It's hard to understand why that camera piece would be so huge, anyway.
  10. Tideland Prius
    16,597
    Yeah I don't see it listed in the PHV's accessory page.
    Me neither. The Bolt uses a small camera, similar to the backup camera (but not fish eye lens).
  11. Salamander_King
    Salamander_King Senior Member
    11,023
    8,958
    New England
    I want this! But probably not for the price they are asking. Japanese genuine Toyota options are soooooo expensive. Do they say how much it cost?
  12. Tideland Prius
    16,597
    59,400 Yen including tax
  13. Salamander_King
    11,023
    8,958
    New England
    Thanks. $536 in today's rate. Not as high as I thought. I guess this figure does not including shipping and installation cost.
  14. Tideland Prius
    16,597
    Keep in mind that it won't work on the Prime. (I guess I should close this thread). The camera is mounted in the rear window so the curved window of the Prime won't work.
  15. Insighter
    409
    287
    SoCal
    I'd pay that if it would work with the Prime. I guess the only questions are whether the rear camera could be mounted to the Prime's hatch window, and if that dead-center vertical defroster at the top of the Prime's hatch window line would be in the way of the camera's lens.
  16. Insighter
    409
    287
    SoCal
    I don't think that is the end of the inquiry. Perhaps it could still be mounted to the Prime's back window despite the curve. Maybe it could be modified or tape used on it. Or maybe that big housing isn't necessary, or another camera could be used with the mirror.
    The central vertical defogger line I mentioned might be a bigger problem.
    One question is does any version of the Prime or other Prius with that curved back window come with this or a similar setup.
    Tideland Prius likes this.
  17. Insighter
    409
    287
    SoCal
    I keep wondering why the back camera housing is so large. A camera certainly doesn't need to be that large. It seems to be purposefully designed to occupy a certain amount of the rear window's real estate. That isn't a good thing, of course. If you have to use the regular mirror, it would be in the way and block much of the view out of the back of the Prius.
    So what could taking up that much space do? Give room for some sort of sensor(s)? It is so large that it looks like it has room for a small solar panel to power the camera, but that wouldn't make much sense. Even if it was that, why not make it wider instead of taller.
    And what is the dark round circle on the side? Some sort of knob? It looks like you might be able to adjust the verticle angle of the camera.
  18. Tideland Prius
    16,597
    Heat sink? (since it'll be fully exposed to the sun). The front LKA camera housing is pretty large too.
  19. Insighter
    409
    287
    SoCal
    It shouldn't need a heat sink, and I wouldn't think black plastic sitting in the sun would dissipate much heat. My dash cam is in the sun constantly with no problems. Still, it is a possibility.
    You make a good point about the front camera's housing being large. I don't know why that is the case, either. At least the front camera's housing isn't blocking anything important in the driver's field of vision. That back one is really, really blocking a lot. I suppose it could be a heavy camera and need a large area for the tape to mount it, but I doubt that. I wonder how bad it looks from the exterior of the car.
    I'm thinking the camera may be motorized and adjustable from the mirror. But that still doesn't explain why the base of the triangle extends so far. It is extending at a widening angle, like the camera's field of vision, so my best guess is that it has something to do with that. I just don't see why that would be necessary. If the camera took advantage of that entire blocked area, all of the defogger lines would get in the way.
    You'd think that in the day of the internet it would be easy to get some detailed photos of all aspects of this setup, but I guess there really isn't a way.
  20. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Given the size and shape, my guess for its largess is to let people "see" what the camera sees. If you made it a tiny bubble, like the minimum the camera and interconnects need, then slapped on a rear window sticker, you might block half your visibility even though the camera itself is unobstructed. The whole delay in video rear view has always been liability issues, not technological issues. This smells like trying to avoid a lawsuit.
