Red triangle of death shows and beeps
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SFPriusonr, May 19, 2018.
  1. SFPriusonr
    SFPriusonr Junior Member
    San Francisco, CA
    lately and increasingly, when I make a sweeping right hand turn, the car beeps and displays the red triangle of death. It will also happen sometimes during an abbreviated stop. At the end of each (turn and stop) it goes away. It happened back in 2015 and the main battery degraded tremendously until I got a refurbished one.
    Could this indicate battery failure, or is the battery loose in its moorings and moves causing motion induced RToD display?
  2. Mendel Leisk
    41,642
    Could it be low engine oil level, and when you go into a turn it sloshes to one side, makes things worse? I think low oil would trigger the oil pressure light though, but not sure.
    SFO and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    One way to find out is to pull the dipstick ;).
    Easy enough to check(y).
    SFO and Mendel Leisk like this.
  4. bisco
    52,093
    who you callin' a dipstick?:cautious:
    SFO, Mendel Leisk and Raytheeagle like this.
  5. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Might be self directed :unsure:.
    bisco and SFO like this.
  6. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Congratulations, you've neglected to check your oil level. Probably will need atleast 3-3.5qts. Expect it to burn even more oil now.
    edthefox5 likes this.
  7. Mendel Leisk
    41,642
    Well, let's wait on the dipstick check.
    Raytheeagle likes this.
  8. SFPriusonr
    San Francisco, CA
    Aha! I guess I am the dip stick... I checked the oil and it was beneath the valley of low. So, now I've filled it up and will take it out for a confirmation spin. But, this begs the question, "Why not the low oil light?" Why wait until the red triangle of death which could mean anything?
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Classic.
    josh2008 likes this.
  10. Mendel Leisk
    41,642
    It's not low oil, it's low oil pressure. But yeah, you'd think that'd be the light that should go on.
  11. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Its throwing the RTOD because your killing the engine. Prius has some monitoring quirks like no temp gauge no oil is low gauge. I guess the
    japs figure you will open the hood once in a while.
    Now the bad news. Usually when a prius tiny little engine only takes 3.5 quarts of oil is run so low on oil it throws the RTOD and you continue to drive knowing full well there is the word death in that acronym it usually means engine damage. At the very least it will become an little oil eating monster. But I would imagine it already eats alot of oil hence the no oil.
    If the damage is really bad you will soon hear bearing knock. Starts as knock only under load then progresses to a loud knock all the time.
    If driven during the loud knock phase usually results in piston #2 through the block. See alot of those here. Always #2.
