2004 Prius Jack Accessories for back tray
Discussion in 'Gen 2 Prius Main Forum' started by zimblon33, May 21, 2018.
  1. JC91006
    JC91006 Senior Member
    16,802
    8,591
    I don't know what to make of the car fax report. You can get a listing of all Toyota dealer services by registering the car's VIN at the Toyota website owner's portal. Once you register the VIN, you'll see exactly what Toyota has done in servicing this car.
  2. zimblon33
    zimblon33 Junior Member
    Grand Rapids
    Oh! I had no idea I could do that. Thanks for the suggestion. I just created an account with Toyota, it looks like the same history. But I can now download PDF's of the entries to see more details, that definitely helps.
  3. Mendel Leisk
    41,778
    Also, what is meant by "battery" in the history; it could be the 12 volt battery.
    Ignore the above, read your posts a little closer.
  4. zimblon33
    Grand Rapids
    Yeah I believe I answered that one in post #20 - " I noticed a 'Battery Replaced' entry from January 2015 at a dealer (this was before I bought it). I just called that dealer, they said it was the 12v battery they replaced. "
