2005 Prius AC Cool not Cold
Discussion in 'Gen 2 Prius Technical Discussion' started by CBandEdith, May 22, 2018.
  1. CBandEdith
    CBandEdith New Member
    Garrison Ky
    Hello and thanks for responding.
    Have a 2005 Prius with 210,000 miles. I really like the car. My AC is full of freon however it only blows cool. Maybe just too hot of a day? Please advise. Thanks
  2. Mendel Leisk
    38,647
    How full? Could be a slow leak. I'd book a dealership appointment, be prepared to spend maybe $150, for them to evacuate it, check for leaks, recharge.
    In the interim, have a look at the sight glass while the AC's running (AC compressor and radiator fans running). You should see little to no bubbles as it running, and a swirl of bubbles when the AC compressor (and rad. fans) stop.
    Addendum: it's not "freon" btw, there's a new refrigerant being used, better for the environment. And I believe a special oil is required. I would not go anywhere but a dealership for this: using the wrong oil could be disastrous.
    • AC.pdf
      File size:
      3 MB
    #2 Mendel Leisk, May 22, 2018
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Ever clean the condenser?
    fotomoto and Mendel Leisk like this.
  4. Mendel Leisk
    38,647
    That's the big radiator on the front, btw.
