Key Fob Buttons Not Working (But All Other Functions Are Fine)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dangr, Apr 6, 2016.
  1. dangr
    dangr Junior Member
    Los Angeles, California
    Hi there!
    I just replaced the batteries in my two key fobs, one of which just ran out, and the other ran out a long time ago but I was too lazy to replace it. One of them now works great, and the other one is... almost there. I can use all the smart key functions (keyless entry, engine start without putting the key in the docking thing, etc.) but none of the buttons (lock, unlock, panic) actually work on the fob. Is there some way to reset this, or any thoughts on what might have happened?
    Thanks so much!
  2. JC91006
    JC91006 Senior Member
    16,674
    8,519
    Maybe 1 of the 3 buttons is stuck.....see if they all click when you press down on them?
  3. dangr
    dangr Junior Member
    Interesting point — the unlock and lock click, but the panic one does not...
  4. JC91006
    16,674
    8,519
    get an exacto knife or a very sharp object and try to dislodge the button. Once it gets unstuck, your buttons will work again.
  5. dangr
    dangr Junior Member
    So, good and bad news — I nudged the button around with my finger, and it sort of snapped back into place. The lock and unlock buttons work now! However, the red part of the other button pretty much immediately fell off, so I guess I'll have to glue it back on. Not a huge deal because I never use that button anyway, but thanks so much for the quick response! This was perfect.
  6. Jls
    Jls New Member
    Tucson, AZ
    Thank you. This fixed my problem. Miami just need to get a second remote and program it.
  7. RobertK
    RobertK Member
    128
    40
    Norfolk, VA
    Sounds like you need a new case for your fob. They cost about $12.00, and you just move the electronics to the new case. Much easier and cheaper than programming a new remote.
  8. RobH
    RobH Senior Member
    2,375
    988
    70
    Sunnyvale, California
    Be sure to transfer the transponder chip as well as the circuit board to a new case.
  9. Isaac Starkey
    Isaac Starkey New Member
    Wisconsin
    My housing was replaced by the prior owner and apparently he forgot to swap the chip. I have a SKS fob so it still starts but if the battery dies in the fob I’m screwed. Anyone have a source I can buy the chip from that never got swapped to the new housing?
