Should I buy this Prius?
Discussion in 'Gen 2 Prius Main Forum' started by plsmoothy, May 26, 2018.
  1. plsmoothy
    plsmoothy New Member
    Just test drove a 2004 Prius base model with 185000 miles on the clock. The girl who drives it knows nothing about cars but she was able to answer some of my questions. The car does not burn oil, the headlights have never had an issue, car has never been in a major accident, the multi function display has never had an issue, and the hybrid battery has never been replaced. She is currently averaging 40 mpg according to the data on the display. She lives in a hot and hilly area of Los Angeles by the way.
    I carefully inspected the car and everything is in good working order ... brakes and rotors, tires, no leaks anywhere, AC works, cv joints/boots are good, all electrical is functional, and the transmission felt smooth. I checked for codes via the OBD II port and found none. The only thing I could find wrong with the car is an alignment issue; it pulls slightly to the right. The body and paint are in good shape with the exception of of a small dent and some scuffs and scratches. I'd would rate the condition of the car as 6.5 or 7 out of 10.
    I'm pretty sure she'll take $3000 for it. I live in Los Angeles by the way. I've have never owned a Prius but I'm just dying to get one. Incidentally I'm very adept at working on cars so if the hybrid battery goes I can buy a rebuilt one and install it myself. So what do you guys think? Any advice for this future Prius owner is greatly appreciated!!!
    m.wynn likes this.
  2. JC91006
    JC91006 Senior Member
    16,737
    8,549
    The answers you got from someone that knows nothing about cars, could just be the answers you want to hear.
    Most likely it's burning oil at 188k miles. Most likely that is not the original hybrid battery. Most likely a base model does not have expensive problematic HID headlights.
    For $3000 why not, but it's most likely not as good as you think it is
    m.wynn and edthefox5 like this.
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Is she the original owner? Run the VIN in the Toyota Owners website to see it's maint. history. I think most of the early Prius were meticously maintained since the early owners were really into the Prius. What does Kelly blue book say it's worth. Don't forget even it's a top notch car now there is quite a few big ticket items on the horizon considering it's age. HV battery ect.
    m.wynn likes this.
  4. plsmoothy
    Hm ... all very good points JC. Does the fact that the car is averaging 40mpg indicate the battery is at least decent?
    Also, do all Prius eventually get to the point where they're burning oil excessively? From what I've read it only happens to some of them.
    Lastly, how well do the other big ticket items hold up over time? Namely the inverter and transmission.
    Please don't hesitate to communicate any other thoughts in regards to the car. Thanks in advance.
  5. MilkyWay
    MilkyWay Active Member
    823
    359
    MI
    I think in other parts of the country it would be about the same price. Since you are in LA I'm surprised it's not up for $6500 lol seems everything is overpriced in Cali. For 3k can't go too wrong I just strongly dislike the 04 and 05 models. No reason other than the interior seems like it was overhauled in the later years. Earlier years feel old and later gen 2 years have a more modern feel.
  6. MilkyWay
    823
    359
    MI
    Probably all of them burn oil at a certain point (300k miles on original engine, for example) but just a guess.
    Trans rarely fails just want to spend the $50 and replace the fluid every once in a while...It's a 20 minute job.
    40mpg is what I get but it can swing wildly based on who is driving. 40 is on the low end. Bet there are people on this forum that would get 55mpg in it.
  7. douglasjre
    douglasjre Senior Member
    2,147
    711
    Null, NL
    It sounds good but I'm amazed how much more CA Prius sell for compared to FL.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    You had me at girl who knows nothing about cars. I want to see some maintenance receipts. She probably is not sure how to open the hood. This is a car that has never seen anything done to it unless it complained.
    Run.
    m.wynn and Raytheeagle like this.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Even with all the "good news" it is, what it is.
    That is, a 14 year old Prius with 185,000 miles on it. You can't really escape that reality.
    If it's the original hybrid battery? Then I'd expect failure in the future. Maybe relatively near future.
    If it isn't the original hybrid battery, rebuilt, refurbished...you're playing cards with a wild card dealt in. Lot's of posts with people experiencing problems with rebuilts and hybrid batteries.
    I wouldn't purchase it, without simply accepting that investment in some form or another is probably very likely as far as the Hybrid Battery goes.
  10. JC91006
    16,737
    8,549
    The prius was designed to go 180k miles relatively trouble free, after that it's a roll of the dice. It could be very good, it could start being a money pit. Chances are it'll still be pretty good.
    I've sold 2 2005 models recently for $3000. Both over 200k miles. 1 was really nice very few issues, the other one burns a quart of oil every 1000 miles and engine wasn't making as much power. Both had it's transaxle replaced, one at 150k miles and one at 250k miles. One was an electrical failure and the other was a mechanical failure. Both cars were averaging over 40mpg and both cars had rebuilt batteries done by myself.
    So for $3000, it's a roll of the dice. Cars will have high mileage, but you MAY be able to find one that's still relatively trouble free, but chances are they are going to be money pits very soon.
