Prius Coolant Pentosin=Toyota Coolant?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jkan2001, May 27, 2018.
  1. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    It's time to drain/refill the coolant on my 2010 prius. If I need to order some parts online for maintenance, does anyone know if this Pentosin A4 is the fluid that Toyota buys and rebadges for their OEM coolant? The specs look pretty similar and it's a HOAT coolant.
    More Information for PENTOSIN 8115209
  2. Mendel Leisk
    38,214
    In a big US city, why not just pick up Toyota coolant, the spec'd stuff, from a dealership?
    I know, that's not the question.
  3. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    448
    186
    Indiana
    2022 Prius Prime
    second this. cost at toyota is about 20 to 30 depending on the dealer. call around to find the best price. IMO not worth the risk, just get toyota stuff.
  4. farmecologist
    farmecologist Senior Member
    1,946
    1,785
    Southern MN
    Third this. It's not like this is a frequent maintenance item so I would pony up for the Toyota coolant..even if it is slightly more expensive.
    BTW - many dealers sell Toyota coolant via Ebay..and it seems to be fairly reasonably priced.
  5. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
  6. padroo
    padroo Senior Member
    2,763
    2,250
    That is a good price. Shipping will be the killer.
  7. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    I put in the Pentosin A4, no issues.
  8. padroo
    2,763
    2,250
    Coolant is one of those strange things, back in the day there was only one color and now every manufacturer has a different flavor and
    you are suppose to use a particular type or bad things will supposedly happen to your cooling system. I am not a chemical engineer but using some logic, aren't the cars cooling systems all made out of aluminum, rubber and plastics. The only thing I can think different are seal compatibility. Anyone have a logical answer?
  9. Grit
    Grit Senior Member
    6,112
    4,040
    Wilkes Land
    @Raytheeagle is one.
    Raytheeagle likes this.
  10. Mendel Leisk
    38,214
    The coolant might react with something in the car, or the previous coolant.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    While the materials haven’t changed, some of the additives in the coolant have. If those additives are co-mingled, incompatibilities May happen. If the incompatibility leads to congealing, plugging results.
    RMB, m.wynn and Grit like this.
  12. Mendel Leisk
    38,214
    It's not just chauvinism, sticking with the factory coolant is one sure way to ensure coolant compatibility. I'm the same with brake fluid, transaxle fluid, even engine oil, though the latter is overkill.
  13. padroo
    2,763
    2,250
    One big change was when they went with aluminum radiators.
  14. eliteconcept
    448
    186
    Indiana
    2022 Prius Prime
    again you may have a dealer in your area that sells this every day for about $20. When I was out of town for work I called the local dealership where I was at and they had it for 20.99, while my local dealership at home had it for like $31 or $32. You may be shocked at your local dealers price (good or bad)
    padroo likes this.
