Solved, rear wheel bearing removal, easy way
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CrniMilorad, Jan 20, 2016.
  1. Merv Himself
    Merv Himself Junior Member
    71
    Georgia, Florida
    2013 Prius v wagon
    Does anybody know if this would be the same process for a 2013 Prius V? ( haven't taken my apart yet to see if things are the same inside.)
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
  3. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    I just used the bolt method on my 2002 Sienna, which has been through 17 New England Winters. It works, but you also must use a good penetrating oil (I used Aerokroil and PB Blaster). One of the bearings was really tough, and my M12 bolts bent (Grade M8.8 = SAE Grade 5). I also used a torch to heat things up, since nothing was moving. Eventually, the penetrating oil started to slip in between the hub assemble and the backing, and finally the second bearing popped, after a couple of hammer blows. Persistence pays. Now, I need to replace a humming bearing on the 2010 Prius.
  4. MrPete
    MrPete Active Member
    500
    190
    Colorado, USA
    I used bolts on my '11 Gen3. Works great. Do this BEFORE hammering... and do it gently (@ChapmanF gives an appropriate warning above.)
  5. rehoboth
    rehoboth Junior Member
    24
    Pittsburgh, PA
    2013 Prius Plug-in
    We just tackled this job tonight after a bad sensor (traced to left rear with the scan tool) gave us a bunch of brake warning lights and kept us from using regenerative braking.
    Replacement sensor, $57 + shipping on rockauto. NSK brand proved to be made in Japan, I guess NSK is owned by NGK according to the blurb on rockauto?
    Yes, getting the original bearing off was painful. This writeup was helpful, although we modified the technique somewhat. I found some long M8 bolts in the workshop, but not long enough to do the originally described technique. So instead, we installed the bolts, rotated the bearing until they were under the studs, then backed them out little by little. Not a beautiful technique but worked, eventually. IMG_20250224_164646.jpg
    MrPete likes this.
  6. Bobert53
    Bobert53 Junior Member
    Mid-Coast Maine
  7. Bobert53
    Mid-Coast Maine
    Great discussion. I've done a couple of bearing/hub replacements on our two Prius. Yesterday, I replaced the rear hub on our 2010 with 180k miles. Here in Maine, salt is the issue, and the undercarriage shows it. That said, I used the bolt method. I tightened up the bolt, gave it a couple of whacks on the cold chisel, rotated and repeated, and off she poped. Removing the hub bolts was the most difficult, 6 pt socket and breaker bar with 'helper'. Removal took about 1 1/2 hr, install 30 min,
