AC problem
Discussion in 'Gen 3 Prius Main Forum' started by priussong, May 29, 2018.
  1. priussong
    priussong New Member
    Sunnyvale
    Hello~
    I'm totally new here.
    I have a 2014 Prius over 55K miles.
    AC is not getting cool. I opened the L cap and pressed with a pin and strong hiss came out so I guess the freon is still enough. What else can I do to check if any leak, or compressor issue? Trying to save $150 by taking it to mechanic. Thanks
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • Did you look for turbulence in the sight glass?
    • Have you tried blasting the AC on low then seeing what the flow in the sight glass looks like?
    • Are there any dash lights on?
    • Have you checked the cabin air filter to ensure it’s clear?
    Keep us posted (y).
    Bay Stater, Mendel Leisk and Grit like this.
  3. JC91006
    JC91006 Senior Member
    16,804
    8,592
    The AC won't be very cold if you let the refrigerant out. Make sure you don't use the ECO setting, that will limit the AC output
    jerrymildred, Mendel Leisk and Grit like this.
  4. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Check if cabin air filter is all gunked up with leaves and dirt. You don't want to have it all clogged like mine posted in the other topic.
  5. Mendel Leisk
    41,792
    Yeah check sight glass, as opposed to releasing gas lol. If you're seeing lots of bubbles, I would go the dealership route, should be around $150.
    Take it or leave it: Its environmentally irresponsible to DIY the AC system, and a mistake or oversight could cost you big bucks.
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    There is another remote possibility: It might be a failing AC amplifier. On some models, you would see an "E" where the outside temp is displayed if it has failed.
  7. priussong
    Sunnyvale
    Thanks everyone. Checked sight glass while AC on low and yes it's bubbly. Cabin air filter is pretty new. No check lights.
    So I guess I should just take it to mechanic to be safe?
  8. Mendel Leisk
    41,792
    Bubbly when running means it's low. Safest bet is dealership.
  9. Black Prius
    Black Prius Junior Member
    Kołobrzeg, Poland
    The lack of refrigerant in the air-conditioning system can be unsealed somewhere on the pipes or cooler, or the compressor itself, or the simpler one is a fuse or relay
  10. phoenixgreg
    1,157
    295
    66
    Phoenix
    Yes, if there is a leak in the system, you'd be better off having a dealer figure it out with florescent dye and a black light.
  11. ChapmanF
    18,426
    In all my days working on cars, I have never seen refrigerant escaping through a fuse or relay.
    (Ok, if you work around people who call a rupture disc a kind of a fuse, I guess I have heard of refrigerant departing through one of those!)
    -Chap
    jerrymildred likes this.
  12. Black Prius
    Kołobrzeg, Poland
    I'm sorry, but the translator translated it to me. It was to me that the gas could escape through pipes or a cooler. The air conditioning fuse is also worth checking if it is not damaged.
  13. ETC(SS)
    7,293
    Mechanic.....yes.
    Dealership......NO!
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Either the dealer or a shop. Just so they know hybrid air conditioning systems.
    Just because it has freon (the hiss you heard) is no indication that it has the right amount. You'll need someone who can locate the leak and fix it. That takes the right tools and training. It can cost anywhere from $200-$1,600 depending on what's wrong. Hopefully, it's just a really slow leak that can be recharged.
