Troubleshooting Prius Daytime Running Lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Feb 21, 2016.
  1. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I replaced my headlight bulbs this weekend, so I decided to check all the other bulbs. The DRL's would not turn on. Since they're LED's and since it was both lights, I ruled out bulb failure and loose connection.
    I switched out the 7.5A fuse and the relay. No luck. The radio has a setting to disable the DRL's. I checked, but the radio set DRL to ON. No DRL's.
    What solved my problem? Release the Parking Brake. The DRL's will only illuminate when the parking brake is off.
    It's just that simple. Thought I'd pass this along. Somebody will google this thread someday and hopefully save some frustration.
    #1 Rebound, Feb 21, 2016
    masdog, HeadOfJarg, baho81 and 3 others like this.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    There's a Parking Brake? But seriously, there's also a setting that enables/disables DRL. This one had me stumped when we first got our car (used) and the previous owner had them disabled...
  3. Jon Watkins
    Jon Watkins Active Member
    131
    115
    Bluffton SC
    2024 Prius
    This really helped me. Who would have known this? Nothing about it in the manual. Changed out the headlight bulbs to Philips x-trememevision and when I checked them no DRL. Of course I had the parking brake on. Turned it off and then had DRL’s.
    I don’t understand why you can turn the DRL’s off? They should just come on automatically when the car is started.
    padroo likes this.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,719
    1,759
    Bay Area
    That is such a useless option to turn off the DRL.
    TXRIFLES83 likes this.
  5. joyjnn3
    joyjnn3 New Member
    Who knows? In places like Arizona, we get very few cloudy days. There's a lot of sunlight, so maybe some folks figure they'll gain more benefit from less electrical pull, than they will by trying to outshine the Arizona sun! Just a guess n
  6. joyjnn3
    joyjnn3 New Member
    Hello, Moderator, can you fix the double quote that appeared and add me a period, at the end? For some reason, I hit the 'n', instead of the period. Heh heh!
    Y'all have a great day!
