dear members i just purchased this car i have seen some caution code on it can somebody advise
Discussion in 'Gen 4 Prius Technical Discussion' started by muhammad jahangir, Jun 5, 2018.
  1. muhammad jahangir
    muhammad jahangir New Member
    pakistan
    dear members i just purchase this car from auction with caution codes on it most important is oil guage level warning i check the dipstick oil seems fine pic attached car is not starting can someone having experience of prius advise me please is it due to these caution codes ecu required resseting or what could be issue your opinion will be very helpfull for me.thankyou
    i got some translation of these faults also
    1 - photo
    Drive start control failure
    Please check with the dealer !.
    2 - photo
    Engine oil pressure shortage.
    Stop in Safe Place.
    3 - photo
    Brake override system
    Malfunction.
    4 - photo
    Front Camera system.
    5 - photo
    LDA breakdown
    6 - photo
    Shift system communication failure.
    When Parking.
    Put a parking brake
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Are you taking the mick with that last photo, dipstick into oil filler, which appears to be full to the brim ?
    If the oil is up to the neck of the filler then it needs quite a lot draining out.
    ZeroDigit likes this.
  3. muhammad jahangir
    pakistan
    Thanks for reply so in your opinion transmission not working and car not starting because engine oil level is exceeding the limit
    But I donot know why this car not starting do you think to restart the Prius with caution code first caution codes have to reset or other reason
    #3 muhammad jahangir, Jun 6, 2018
  4. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    Disconnect 12 volt battery for 10 minutes, push start button with foot on brake, then reconnect 12 volt battery. Try to start again. Do all messages come back?
  5. muhammad jahangir
    pakistan
    Ok I will try this and will get back to you thankyou for taking interest in this problem
  6. Mendel Leisk
    41,713
    Ok, I had to look up "taking the mick", means having someone on, joking?
    I think the oil level is fine: it's really hard to read, especially clean oil. Also the dipstick tube tends to collect oil the first time you pull it out, then deposit it up and down the dipstick as you push it back in for the check. The remedy for that is to wait at least 5 minutes for that second insert, give the oil in tube time to drain down. But as I said, the darker colour zone seems to stop at the top mark, I think that's the actual level.
    It's not warning of low oil level, it's warning of low oil pressure. For some reason. Often it's due to low oil, but maybe not always?
    Andyprius1 likes this.
  7. bisco
    52,136
    welcome!
    check the 12v health.
  8. bisco
    52,136
    i learned that one from harry potter.;)
  9. muhammad jahangir
    pakistan
    sir i have seen ur comments always full of information
    did you see the warning triangle on top of transmission and engine not starting low oil level light or low oil pressure indication how to resolve these issues
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I was referring to the last picture, it shows the dipstick laid across the oil filler neck with the cap off and the cam cover appears to be full of oil up to the top of the neck. :eek:
    has he dipped the dipstick into the oil filler neck ??
    Mendel Leisk and RCO like this.
  11. Mendel Leisk
    41,713
    Good point!
    Never noticed that. Unless it's a trick of the lighting, it does look like it's full to the brim with oil. You should not be seeing oil pooled that high, that's the zone above the camshafts, should be clear and dry, with the car sitting off. Here's a pic of my third gen, fwiw:
    @muhammad jahangir can you confirm about oil level? If you're seeing oil right up to the neck of oil fill cap that is wrong, way overfilled. In that case you should drain completely and (assuming you leave the oil filter as-is) then add 3.9 liters only.
    Note, for the 4th gen oil change instruction, see the first post here:
    Official (OEM) Toyota Prius 2016 (Gen 4) oil-change instructions | PriusChat
    And a pdf version is attached, in post # 2
    Still, if oil was grossly overfilled, you may have ongoing problems, oil may have gotten into places that don't readily drain.
    #11 Mendel Leisk, Jun 7, 2018
    RCO likes this.
  12. bisco
    52,136
    would the dipstick only show half way between min and max?
  13. Mendel Leisk
    41,713
    Maybe someone with a fourth gen can snap and post a pic of what theirs looks like, with the oil filler cap removed? Something is not adding up:
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    If it's been filled to the top, there could be a hydraulic lock in one or more of the cylinders if it was started. Could be a bent con rod and all sorts of problems.
    Andyprius1, Mendel Leisk and bisco like this.
  15. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    That's a plastic oil baffle. Here's a few shots of mine.
    kithmo, Mendel Leisk and krmcg like this.
  16. muhammad jahangir
    pakistan
    so whats your opinion about this issues
  17. muhammad jahangir
    pakistan
  18. priusgto
    194
    231
    Northern Arizona
    Start with the batteries and, like others have suggested, make sure they are good. About the other only thing I can suggest is to find the latest Techstream software and an interface cable (VCI) to clear all the codes and diagnose the issue, or have it done by a dealer/shop. Without diagnostic software you'll be in the dark and have nothing but aggravation trying to guess.
  19. muhammad jahangir
    pakistan
    ok well noted thankyou
  20. Al Bundy
    Al Bundy Member
    140
    69
    florida
    i would say the 12 volt battery is low/weak..Disconnect it , charge it fully and see if that fixes your problem..dont forget to have your foot on the brake fully when starting the car... I know on older Prius that would cause many error messages on the screen and the car not to start.. you said the car was at auction, was it damaged in an accident?
    Andyprius1 and bisco like this.
