P0A93 Concerns
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Themsah, Jun 7, 2018.
  1. Themsah
    Themsah Junior Member
    Savannah
    2008 with 202K miles
    So I know this code is a bit of a dead horse around here. Should be just swap out the coolant pump and be done with it. I have a what I think is a different issue.
    6 months ago I swapped out the 3 way valve and had to bleed my system manually which took hours. Car has run like a top since. I had the recall done on the coolant water pump maybe 5 years ago.
    Now I have the red triangle of death coming on after driving about 15 mins. I can manually run the pump and it runs and sounds fine. All coolant levels are good and I believe there is no air in the system.
    Is there anyway I can diagnose that it is indeed the pump that is bad and not something else?
    Thanks in advance
  2. JC91006
    JC91006 Senior Member
    16,482
    8,400
    Which pump are you running manually? The error points to the electronic inverter pump, there shouldn't be a manual way to run it.
    Skibob and Themsah like this.
  3. Themsah
    Savannah
    I am jumping the relay for the inverter pump. The same way you bleed the system.
  4. JC91006
    16,482
    8,400
    Maybe you have a bad relay?
    Themsah likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,228
    5,911
    Columbia, SC
    Just had a co-worker with very similar symptoms last week. Also a 2008 with about 180k miles. After about 15-20 minutes of driving, a P0A93. She had it taken to dealer and they wanted $670 to replace the inverter pump. That was not an option for her. They cleared the codes and she drove it home. Coded again on the way home. Got in contact with me through a mutual friend. Sent me the dealer report via phone message. Got a pump through AutoZone for $157 total out the door (high $, I know, but no other option at the time) and went to her house the next day. Hooked up techstream, knocked out a health check and spent about 20 minutes showing her some things on TS. Same info as dealer report provided. Physical testing? .... All indications when cold were that the pump was running and operating. After speaking to her about the pump recall, she called the previous owner (mom) and found out that it had been done a handful of years and many miles ago. Snatched out the driver headlight, clamped off the hoses, swapped the pump, bled out the trapped air and added about 4 ounces of fluid to top it off. Bunches of ripples in the reservoir. Techstreamed it again to clear all codes. Seeing as I was never there to diagnose the problem when it happened, and I'm confident any pump can have an intermittent failure mode, it made sense to me to believe what the car was telling me. It's been 6 days since the pump swap. No codes. Problem solved? Most likely. It was 90 minutes from the time I left my house until I was back home having a
    Get in the car. No foot on brake. Press start button wait a couple seconds and press it one more time. The pump should run and you should have flow in the reservoir. Her pump ran and had flow. After swapping the pump, it had noticeably more flow. If the pump isn't running, then you could very well have a bad relay, especially if the pump runs when you bypass the relay. Other than that, sometimes you just need to believe what the car is telling you.
  6. TMR-JWAP
    6,228
    5,911
    Columbia, SC
    I'm not familiar with this method. On inverter pump swaps, I just connect a rubber tube to the bleeder valve and put the other end into the reservoir. Press the start button twice to put car in accessory mode and the pump runs. Air bubbles and fluid pass through the tube into the reservoir and I add fluid as needed. Works just like a brake caliper bleeder valve.
    Muneeb and Themsah like this.
  7. Themsah
    Savannah
    Thanks for this input. I found a pump on Amazon for $65. I ordered it. I figure whats the worst that could happen? I am going to try the relay when I get home today. But I agree, sometimes you just have to trust what the car is telling you. Fingers crossed the pump fixes it.
    THANKS AGAIN
  8. TMR-JWAP
    6,228
    5,911
    Columbia, SC
    Themsah,
    Also want to mention, when you do the pump, just use clamps on the hoses instead of draining the system. Makes life much easier. Clamps are available at autozone (3 sizes in a package) for about 15 bucks, or about 10 bucks for same thing at harbor freight.
    Themsah likes this.
  9. Themsah
    Savannah
    Yeah I wish I had those when I swapped out the 3 way control valve. It took me hours to bleed the whole system.
  10. Themsah
    Savannah
    So I just got home and went pressed the power button 2x without stepping on brake. Pump does not run, I swapped relays, pump still does not run. I jump the relay and it runs fine. Any thoughts? I already ordered the amazon pump and will install once it gets here. but now I am nervous its not the pump or relay. What sends the signal to the relay? The computer?
  11. Themsah
    Savannah
    Also side note, when I run the pump manual there are no ripples in the res tank and there is little to no pressure when I crack the bleed valve.. :unsure:
  12. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    Maybe a blockage in the inverter? There have been a couple of posts very recently where blowing air through the inverter cleared a blockage caused by slime/jellified coolant.
  13. TMR-JWAP
    6,228
    5,911
    Columbia, SC
    The first thing that pops in my head is: is the "jumped" relay powering the inverter pump or something else? like maybe the pump that moves coolant between the engine and storage tank?
  14. Akathef
    Akathef New Member
    Touring + Tech
    Are there any gaskets that should be replaced while putting in the new pump? 2009 186k with a returning P0A93 code going to buy the inverter pump off of amazon but after calling the local parts store they told me that i should also purchase the gasket set.
  15. TMR-JWAP
    6,228
    5,911
    Columbia, SC
    The last time I replaced an inverter cooling pump it only had hoses connected to it. I'd be curious as to where a gasket could be replaced.
    Granted, I replace these pumps by removing the driver side headlight and using pinch style hose clamps to stop any drainage from the hoses. Maybe they're assuming you're going to drain all the coolant from the inverter loop and want you to replace the aluminum crush washer at the drain plug. If that's the case, then they're talking about a 50 cent aluminum crush washer. The Toyota Inverter cooling pumps I've purchased have always included this crush washer in the box.
    #15 TMR-JWAP, Mar 3, 2019
    Skibob and Dxta like this.
  16. JC91006
    16,482
    8,400
    P0A93 does not necessarily mean you have a failed inverter pump. If there's no power going to it (like if a rat chewed some wires), you would also get that code.
  17. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Always the rats get the blame. What if it was the chipmunks? They never seem to get the blame. :ROFLMAO::ROFLMAO::ROFLMAO:
  18. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Recall from my vehice you and I deduced about 80000 miles life on those pumps, and then consider replacing.
  19. JC91006
    16,482
    8,400
    I think 80k miles is a good guideline. Although some low mileage cars with 60k miles are now on their 3rd pump
