New Noise as of Last Night
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MPGHokage, Jun 11, 2018.
  1. MPGHokage
    MPGHokage Junior Member
    Utah
    Last night I went for a drive, and the road turned to dirt.. I drove about a mile on the road before I turned around. Then afterwards My car started making this sound.. There's nothing dragging, and I cant seem to figure out what it is.. any ideas? Thanks!
    52,395
    just a wag, but it could be a loose under panel. does the gen 1 have those?
  3. MPGHokage
    Utah
    oh i need to fix my profile. I bought a 2008
  4. fuzzy1
    10,603
    In the old days, that could have been gravel rattling inside a hubcap. But that may be inconsistent with any Prius wheel cover configuration.
    Could some gravel be rattling between the brake disk and some sheet metal shield around the brake caliper? Do a few wheel revolutions in Reverse change everything?
    #4 fuzzy1, Jun 11, 2018
    edthefox5 and paprius4030 like this.
  5. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    It does sound like something sliding in something circular, like loose gravel.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Like Fuzzy says sounds like rock in between the caliper dust plate and the rotor. But the loud crash at the end where you run over something good god whats that noise lol?
  7. fuzzy1
    10,603
    To me, that sounded like a loose manhole cover or expansion joint.
    edthefox5 likes this.
  8. MPGHokage
    Utah
    It was I was only half paying attention to the road
  9. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    +1 on a stone in a brake mechanism. Have someone walk alongside you as you drive slowly to pinpoint which wheel, but given the noise front left is likely.
    MPGHokage likes this.
