94 octane gasoline = quieter ICE
Discussion in 'Prime Main Forum (2017-2022)' started by bb4srv, Jun 15, 2018.
  1. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    First refill of gasoline since I got the vehicle in March. I figured for the little gas I use, I'll use the highest octane. I am fully aware that the car does not need 94 and I do so out of my own choice! For the fill, I also put in STP fuel stablizer b/c the gas will be stale by the time I deplete the tank.
    Interestingly, after putting in 94 (fill from 1/2 remaining bar), I find the ICE operation at low rev and idle much quieter and less vibration. When accelerating, the intake drone still present. But when cruising and idling (when warming up) there is hardly any noticeable vibration and is much quieter. I had to double check the "EV" icon to make sure it was not lit up and that the ICE was in fact operating.
    This is a contrast to gasoline from the "complimentary" tank when I received the car new, where it is subjectively appears to be louder at operations (b/c I would certainly notice it) and more vibrations at idle (when ICE is warming up). In fact, my first observation in HV mode was this car is quite loud/vibration (much more than my old CT200h). So I'm not sure if the dealer complimentary tank was super stale old gas at 87 or less octane, or whether 94 does make car quieter. I guess I'll try another tank of 87 after I depleted this tank.
    Just my observation.
    #1 bb4srv, Jun 15, 2018
  2. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    But we'll need to wait such a long time before that happens!
  3. Mendel Leisk
    41,828
    What brand, probably Chevron? More-n-likely ethanol-free then; did you check: the stickers on the pumps? Here in greater Van there's invariably a sticker on the 94 octane saying ethanol-free. The other octanes say "may contain up to 10% ethanol". Swing back and take a look?
    Best tank we've ever had, I filled up at a Chevron up the coast, just regular, and it was miracle fuel. The liters per 100 km went down and stayed down, without even trying hard. More or less the best tank we ever had. Reading up a bit, I saw some reports that small town stations are more likely to have ethanol-free, the logistics of getting ethanol blend to out-of-the-way places sometimes make it impractical.
  4. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    Yes, is Chevron 94 Octane and is ethanol-free. Where I live, the only ethanol-free gas is 94 octane. Anything less than as max 10% mix.
    HPrimeAdvanced likes this.
  5. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    I only refilled 1/2 the tank. So I'll update in approx 2 months after I run this down and refill with 87.
  6. bisco
    52,292
    interesting, i've never heard that higher octane could quiet an engine. will be watching to see your next fill up, all the best!(y)
    rajoneshsv and kenoarto like this.
  7. Salamander_King
    Salamander_King Senior Member
    11,023
    8,962
    New England
    So, your current tank is 50:50 of old gas of unknown origin:ethanol free 94 octane gas. In 2 months, when you fill half tank with 87 octane gas with ethanol, your tank will be 25:25:50 of old gas of unknown origin:ethanol free 94 octane gas:87 octane gas with ethanol. Not the same as your first tank.:p
  8. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    No, 1st tank i depleted to maybe 1/2 remaining bar left on the last slot. So almost empty. I put in around 10L of 94 and the gas meter shows 50% full (or empty).
  9. Salamander_King
    11,023
    8,962
    New England
    Oh, I see. In that case, in 2 month you will be depleting most of current gas and replacing it this time with 87 octane with ethanol of known origin. As @Mendel Leisk eluded to you, it may be "ethanol free" that did the trick.
  10. breakfast
    breakfast Active Member
    266
    199
    In any event, the thread title statement "94 octane gasoline = quieter ICE" is at best "yet to be proven" and at worst incorrect or misleading. Perhaps it should be re-phrased as a question...
    burnout8488, douglasjre, Db17 and 2 others like this.
  11. bisco
    52,292
    might be helpful for others to try it and report back.
    kenoarto likes this.
  12. Trollbait
    12,653
    Computer controlled engines push the ignition timing to the edge of starting to knock for better efficiency. Knock sensors are actually microphones listening for those first knocks. If being at that point means a 'louder' engine, then a higher octane fuel that isn't near knocking at the engine's most advanced timing should be quiet in comparison.
    I'm in the lack of ethanol being the reason camp. Not because of the ethanol directly, but because it is carrying water with it into the cylinder. 10% ethanol is really about 9.5% ethanol and 0.5% water, and it might even have more water than that.
  13. Mendel Leisk
    41,828
    Worth noting: it's my understanding that all grades of US gas are 10% ethanol, whereas up here it's 10% in regular, 0% in the station's highest octane, and the mid-grade is likely a mix of the other two, around 5%. Shell stations typically have a decal saying in effect:
    Regular: 10%
    Mid-grade: 5%
    High-grade: 0%
    And while they don't come right out and say how that comes to be, it seems plausable that mid-grade is just a mix.
    Chevron, there's three pumps say "may contain up to 10%". Then an by itself pump, Chevron Supreme, octane 94, with the decal emphatically saying no ethanol, words to that effect.
    I would just kill for some regular ethanol free. It's frustrating to have to pump Chevron Supreme, basically a higher octane, harder to ignite fuel, designed for sports cars with high compression engines, in order to dodge ethanol.
    Tim Jones likes this.
  14. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Hmmm, well Pearl S runs quieter after I wash and wax her.
    Just saying. ;)
  15. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    I bet she glows a bit too:p.
    Tideland Prius likes this.
  16. Mendel Leisk
    41,828
    Till OP comes back it's speculation, but it's pretty much for sure (ethanol-free) Chevron Supreme Plus.
    After we got that ringer tankful up the coast, I even emailed them, asking about ethanol in small town stations. They never responded, of course.
    Ah, here we go, visual aid, Canadian Chevron pump:
    TGrracie and audiodave like this.
  17. Trollbait
    12,653
    Midgrade is a mix of regular and premium. Blender pumps mix and dispense it at the pump. Stations without those pumps have a midgrade tank in which the delivery truck mixes the regular and premium together.
    Midgrade isn't a 50:50 mix. For US 89 midgrade, it is a 2:10 ratio of 93 premium and 87 regular. I have used that ratio to mix midgrade in my car's tank, But I found it a bit cumbersome to bother with regularly.
    E10 availability depends on regions and states in the US; more likely in metropolitan areas. Where it is, the "may contain up to 10%" stickers are the most common. There is a station about 40 minutes out of way that has ethanol free regular. It is closer to some lakes, so is likely there for boats. Premium is not guaranteed to be ethanol free; ethanol is used as an octane booster.
    Higher octane gas is not harder to ignite with a spark plug. It can withstand higher compression pressures before it spontaneously ignites.
    edit: Just occurred to me that HCCI(diesel like gas) engines like Mazda's might have a maximum octane requirement.
    #17 Trollbait, Jun 15, 2018
  18. Mendel Leisk
    41,828
    I've run a tank of Chevron Supreme Plus once or twice, soon after the "miracle" tank from an up-the-coast station, didn't notice much. A little disappointing. (n)
    To topic-drift a little, I just dosed the latest tank with the proscribed amount of this:
    The back-label says it has petroleum distillate and Polyetheramine (PEA). I was looking for Chevron Techron, but seems like you can't get it up here, or it's expensive on Amazon. Someone speculated it was due to the need to create bilingual labeling, tabernac...
    It just seems like the spring mpg improvement is a no-show, so trying one thing at a time, I thought I'd give this a try.
    #18 Mendel Leisk, Jun 15, 2018
  19. El Dobro
    El Dobro A Member
    7,088
    3,270
    rcaine likes this.
  20. Mendel Leisk
    41,828
    To the best of my recollection every fillup has been Chevron.
