Battery acid is eating exhaust shield
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zander, Jun 8, 2013.
  1. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    *but* a feed from the inverter serves as a "virtual alternator" providing regulated charging voltage for the 12V battery from the traction battery any time the car is in Ready mode.
    52,396
    except in neutral?
  3. El Dobro
    El Dobro A Member
    7,093
    3,271
    The caps are usually under the labels on top of the battery, so you don't mess with them.
  4. zander
    zander Junior Member
    46
    connecticut
    First: I think for safety reasons the vent tube end for the battery is located above the exhaust shield, I think that's a BAD location, I will stop by at the dealer and show them the problem to see if can be resolved by a safety recall. I think I may have put to much H2O in each cell( 2 oz) I should have put 1 0z in each cell. Next if I replace the battery Exide has 4 year replacement optima has 3 year, my concern with the optima is this is a sealed battery, no vents and what would happen to the battery if the charging system went wild
  5. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I'm not sure you understand. You're not supposed to put *any* water into an AGM battery.
    WE0H likes this.
  6. bisco
    52,396
    i'm pretty sure the correct optima has a vent?
  7. Bill Norton
    Bill Norton Senior Member
    2,219
    745
    MONW, Ks.
    2019 Prius
    L Eco
    Just for reference, there is a DC to DC converter that comes online when the car is in Ready mode.
    It converts the HV DC ( +200vdc) to the 12 volt bus ( ~14.5vdc).
    That the LV battery is only for boot up of the system and ACC mode, interior lights, etc. when not in ready mode. The battery 'floats' on the 12v bus when in ready, there is no battery charging system as such.
    The boot up is a brief + 20 Amp load, I have read here. That battery has an easy life. There is no overcharging.
    OP, you screwed up your battery and made a big mess.
    The Owner's Manual, the Big Label on the side of the battery and the fact that there are no visible servicing ports
    should have been a tip that you don't dick with this type of battery.
    Are you really going to the dealer with this problem you created and tell them "I think I may have put to much H2O in each cell"
    Better luck with your next battery,, whatever that may be.
    For the tech crowd, here's a good primer on Prius electrical system attached. It does not show the location of the DC to DC converter but I'm pretty sure it is located in the HV battery area.
  8. wjtracy
    wjtracy Senior Member
    11,372
    3,608
    Northern VA (NoVA)
    Yes the Optima has a vent tube for gases (H2).
    For Zander I probably recommend Optima or the Toyota OEM replacement.
  9. Bill Norton
    2,219
    745
    MONW, Ks.
    2019 Prius
    L Eco
    Yeah, Optimas are the way to go!
    And then, I recommend cleaning up the big mess you made with baking soda.
    Use some corrosion preventative, like LPS 3 in the area and on all the battery hardware.
    ( hopefully this will stop the rust and corrosion that you created inside and outside of the battery area )
    Close up the access panels to the battery...
    And never go there again for at least 3-4 years.
  10. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    what alternator he has a prius !!!!
  11. doc2mee
    doc2mee Junior Member
    Why do you need to add water to a AGM battery?
    It is sealed, the hydrogen produced when charging is converted to water via Manganese Oxide catalytic converter.
    Oxygen is produced when discharging and stored inside the each cell with manganese converter forming manganese oxide and when charging hydrogen produced will the interact the manganese oxide forming water. That is why there will never be excess water in the battery.
    By tampering with the seal,O2 & H2 will leak into your car compartment, when overcharging acid steam will vent out. Not only is your car hazardous to fire, it is now poisonous from acid fumes besides the water level will dry out due to imbalance in the water recovery of the MgO2 converter.
    Bill Norton likes this.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    To the OP.
    I'd advise, clean up the battery acid as carefully and thoroughly as possible.
    Then replace your battery with a new AGM no maintenance battery.
    Don't add water to it.
    TMR-JWAP likes this.
  13. WE0H
    WE0H Senior Member
    3,247
    528
    That's a neat document ;)
    tnx
    Mike
    Mobile on my SGH-i717
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Oh my god....I don't know exactly how I got onto this thread and I apologize for bringing it back to the top, but I've been laughing so hard I'm about ready to puke. I actually had to go back and read the original thread where the water was added to the battery at the 49k mile point.
    omgomgomgomg
    PEOPLE....please don't take your AGM battery, remove the large sticker label on the top, pry off caps (that are under the sticker label) and add water. Over and over and over again. I would imagine it kept getting "low" because it was blowing out the vent tube after each "fill up". omgomgomgomg
    And if you do, then have a bunch of electrolyte/acid blow out the vent tube to the exterior of your car, please just hang your head in shame and go buy a new battery. Don't go to the dealer and try to make it into a safety recall issue. Can you imagine the look on a tech's face when they hear the story? To have a sealed battery, go through all the work of unsealing it and adding water. Does that even pass the common sense test? At all?
    padroo and jerrymildred like this.
  15. ChapmanF
    18,557
    But anyway as long as we're at it:
    Well, happily, the ~ 14 volts from the converter is enough to keep a 12 volt battery charged.
    The converter is located up front in the inverter/converter assembly, callout ❹ on page 5.
    -Chap
    jerrymildred likes this.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Well, I know how I got onto it. You floated it to the top. I'm glad you did. It was pretty incredible. But I rolled my eyes so much, I may have pulled an eyeball muscle. :ROFLMAO:
    padroo likes this.
  17. jack black
    jack black Active Member
    225
    142
    I
    This reminds me a story about a prius owner inflating tires to 100PSI, bringing the car to dealer for service, tire bursting injuring a tech, and owner having a fit about lost tire and car damage. Being a prius owner is no guarantee of being sane.
  18. ChapmanF
    18,557
    Good conditioning exercise for 2018 in general.
    -Chap
    CR94 and jerrymildred like this.
  19. padroo
    padroo Senior Member
    2,763
    2,252
    I hope Sam Spade doesn't see this thread. :)
  20. Mendel Leisk
    41,914
    Just don't say the name three times in a row...
    padroo likes this.
