2013 Scion FRS Wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by firemechanic, Feb 1, 2013.
  1. Farhan uddin Ahmed
    Farhan uddin Ahmed New Member
    sharjah united arab emirates
    Three Touring
    Guys I just bought a brand new Prius 2017. I didn't like the 15" OEM rims. So i bought a slightly used set of 17 " BRZ wheels. But the are jamming on the calipers. Pls advise what size spacer to be used both for front back, as all wheels are jamming on the calipers
  2. Bill Norton
    Bill Norton Senior Member
    2,146
    734
    MONW, Ks.
    Buddy,
    That's what this whole long thread is about.
    Pls read the thread and advise yourself.
    (I shaved the caliper carrier and didn't use any spacers...)
    Starbrand likes this.
  3. Farhan uddin Ahmed
    Three Touring
    Thanks. Its done now I have installed the rims and used 3MM spacers all around.
  4. ejceles
    ejceles Junior Member
    okc, ok
    Just wanted to say thank you to everyone who contributed to this thread. I paid 425.00 for my new take off wheels and tires, 55.00 for lugs, spacers, and hubcentric rings on eBay. I also bought TRD lowering springs and lower chrome molding for 329.00 from oem parts world. So I got this look for around 800.00 total. I used the information from this thread and the lowering springs DIY thread.
    #224 ejceles, Jul 17, 2018
    hw30_, GTprii and James Powers like this.
  5. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
  6. stormgrey
    stormgrey Junior Member
    Birmingham, United Kingdom
    ----UK----
    The wheels catch the calipers at the front AND rear so you need 3mm rear spacers or work on the caliper bridges as others have stated
  7. ejceles
    okc, ok
    I don't know if those spacers will work or not. All you need is 3mm of clearance.
  8. Jchoi808
    Jchoi808 Member
    30
    25
    Mililani, HI
    2018 Prius Prime
    I just installed my FRS wheels with 3mm spacers and worked out great. Question on the TPMS, I bought a new set for the FRS wheels and installed them with new tires. When I put the new wheels on the car it didn't throw the TPMS light on the dash like I was expecting. The new TPMS did not get entered into the system and thought it was quite odd. I know that my old ones worked when I got a flat tire and even today with the new wheels the light comes on when I start the car but turns itself off. Any thoughts?
  9. Jchoi808
    Jchoi808 Member
    30
    25
    Mililani, HI
    2018 Prius Prime
    Just a quick update, it took 5 days but my TPMS system finally noticed the lack of the old sensors and is now throwing the TPMS indicator on the dash.
  10. georgegui
    georgegui Junior Member
    31
    46
    Same here, throwing TPMS on the FRS wheels after installation. I've read the previous posts and found the following solutions but am wondering what is best?
    1. Have a shop install the original Prius TPMS in the FRS wheels. (valid)
    2. Reprogram the TPMS using techstream (not validated)
    3. Use the TPMS reset trick (which i don't know how "permenant" a fix is) anyone else try this below and confirm that it works long term?
    I suggest you fill tires to 40psi and reset tire pressure warning system, then reduce to desired pressure like 36/38 or ??? This way the warning light goes off at 30psi. Warning light is 25% loss of air when system is reset. Reset instructions are simply:
    1. Engine off, adjust inflation.
    2. Turn power switch to ON, then press and hold reset switch until warning light blinks 3 time slowly. Reset switch is under drivers side dash.
    3. Done. Now turn the car off and reduce air pressure to what you want.
    BTW, factory 17" wheels recommends 33 front / 32 back although most run more air for better mileage.
  11. georgegui
    31
    46
    Here's my wheels with Michelin primacy got them off eBay for 700 shipped
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    This photo is like people installing new led lights and posting photos of the car with lights off.
  13. georgegui
    31
    46
    What u can't see the wheels? Lol get your eyeglasses on old man
  14. Itsmyprius
    Itsmyprius New Member
    I know this is old but get a flapper disc and grind caliper brackets a little bit and done, no spacers and no extended studs...save a bunch of money and no bullshit
    privilege and Bill Norton like this.
  15. Bill Norton
    2,146
    734
    MONW, Ks.
    I agree.
    I measured that 'bridge' of steel between the pad sliding surfaces, before and after thinning it enough to clear the wheel to create 1-2 mm of clearance.
    I removed less than 10% of the thickness in just that area that would make contact with the wheel.
    No big engineering deal....
    privilege likes this.
  16. meteve
    meteve Junior Member
    Orange County, CA
    2013 Prius Plug-in
    Has anyone tried putting on the Toyota 86 rims (2017-2018) with a gen3 prius?
  17. 04priusnow
    04priusnow Active Member
    345
    201
    same size unless you get the Toyota 86 trd .. that has 18" wheels that are 7.5" wide rim. not sure if it will fit
    Pixel 3a XL ?
  18. Infamous6i9
    Infamous6i9 Junior Member
    61
    Los Angeles
    so how many turn were you able to make with this?
    Prius4Jesus likes this.
  19. Prius4Jesus
    Prius4Jesus New Member
    Tucson
    I
    Hey guys I've been learning through this thread (thanks a bunch) and recently pulled the trigger on a set with tires (80% tread) for a great price. I'm only getting 5 and 1/4 turns with the Motorsport-Tech Adapters and Gorilla lug nuts, so I scooped the Dorman 97206.1's on Rock Auto for $1.50 a piece! They're on clearance right now. I'd post a link but can't as I just joined. Just search that part number with Dorman and it will pop up.
    I'm also going to soon be installing TRD Springs and new struts/shocks all around.
    Bill Norton likes this.
  20. Bill Norton
    2,146
    734
    MONW, Ks.
    Nice! Depending on the tires your car must feel 'sportier', but it's less fuel efficient.
    Also,,,, WWJD?
    Would all this Fun Money be better spent on helping the hungry, homeless children in your area?
