Button ID help...is this stock or added by someone?
Discussion in 'Gen 3 Prius Main Forum' started by WhiteShadow, Jun 18, 2018.
  1. WhiteShadow
    WhiteShadow Junior Member
    Folsom, CA
    I've had this Prius for almost 3 years and I've never noticed this button. It resides just to the right of the hood release. Any ideas?
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    Judging from it’s out-of-the-way position, I would venture a guess that its part of an after market alarm system.? To say the least, from an after market accessory of some sort. Most certainly it is not a stock configuration.
  3. WhiteShadow
    Folsom, CA
    Yeah, I agree it looks aftermarket. There is no alarm on the car that I know of.
    Thanks
  4. WhiteShadow
    Folsom, CA
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,058
    786
    Virginia, USA
    Agreed. Unfortunately, they violated the #1 rule in after-market installation which is: "drill no holes; a good install can be returned to 100% OEM." Considering the number of unused blanks on the dash, it's surprising.
  6. RoadNoise
    RoadNoise Active Member
    136
    187
    Huntsville, AL
    Two Eco
    Oh darn. My hopes for an ejection seat dashed!
  7. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Some dealers put the KARR system on early gen 3's to protect theft off the lot. It has a few more bells and whistles than the OEM alarm: Motion detection with "warn away", shatter sensors for glass breakage, rolling codes and valet mode. Here's a writeup on how it works: (If it ain't broke, don't fix it!)
    Re-programming KARR alarm
    Make sure Karr is disarmed (no LED lights)
    Turn Prius on
    Press and release Karr button 3 times
    Short LED light with 1 short horn
    Before 3 seconds, turn Prius off
    Horn will give a short-long chirp
    Within 3 seconds, turn Prius back on (now in programming mode)
    Horn will give a long-short chirp
    Press Karr button one time per option (there are 4 options) the Karr LED will flash the number of times per option you are on.
    Option 1 (one flash): wait ½ second and horn should chirp once (auto-lock with ignition on)
    Option 2 (two flashes): wait ½ second and horn should chirp once (auto unlock with ignition off)
    Option 3 (three flashes): wait ½ second and horn should chirp twice (passive arming and lock without lock)
    Option 4 (four flashes): wait ½ second and horn should chirp twice (active arming)
    Turn Prius off to exit programming.
    Get out and arm…LED should flash.
    Wait a bit and then attempt to disarm with fob.
    Valet mode – car on, press and hold for 5 seconds until solid blue LED
    Valet mode off – within 3 seconds of Prius on, press and hold until LED off
    Robert Holt likes this.
  8. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    HA! Couldn't resit!
    RoadNoise likes this.
