toyota.com/owners vs. Service Writer - BEWARE!!
Discussion in 'Gen 2 Prius Main Forum' started by egg_salad, Jun 19, 2018.
  1. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Short version...
    As my new-to-me '08 approaches 100k/10 years, I thought I ought to do some maintenance.
    The toyota.com/owners website lists the last service record (3/31/17) before I bought the car. It says (in part):
    "CUSTOMER DECLINED THE FOLLOWING, COOLANT DRAIN AND REFILL, REPLACED ALL SPARK PLUGS, HYBRID BATTERY FAN SERVICE, HYBRID INVERTER COOLANT DRAIN AND REFILL, REPLACED BOTH FRONT WIPER BLADES "
    So I did the plugs last week - they looked lovely and came out easily, mind you. Today I brought my car to the dealer to have them do both coolant changes. The quote was surprisingly low!
    But when I sat down with the service advisor, he looked up the service history and told me all of that HAD BEEN DONE on 3/31/17, and even showed it to me on his screen.
    I'm 100% certain that he's not going to lie to me to prevent me from spending money! Also of note, when I first got the car I went in to clean the HV battery fan and found it spotless - which the Service Advisor also showed me was cleaned on the 3/31/17 service.
    The info at toyota.com/owners is only as good as whoever input the data. In this case, not very good.
    So I wasted $35 on replacing 15-month-old spark plugs. Good thing I saved the old ones!
  2. orenji
    orenji Senior Member
    5,887
    3,488
    Yes, only the dealer has actual history.
    Mendel Leisk and egg_salad like this.
  3. JC91006
    JC91006 Senior Member
    16,764
    8,562
    Unless you plan to do another change in 150k miles, you can donate those plugs.
    The person that inputted the info must type "customer declined" a lot, just keep repeating those words
    egg_salad likes this.
  4. egg_salad
    545
    426
    Las Vegas, NV
    BTW, I'm also fascinated that the PO spent somewhere around 800 bucks on service 6 months before trading it in. Thankful, mind you, but fascinated.
  5. orenji
    5,887
    3,488
    Happens all the time, they walk the showroom while the car is being serviced and get the new car bug!
  6. egg_salad
    545
    426
    Las Vegas, NV
    I wasn't tempted by any of the new models, but on the showroom floor was a 1984-ish Land Cruiser BJ70 RHD soft-top Diesel that caught my eye!
    m.wynn and orenji like this.
  7. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Huh. Just because I saw this I entered my VIN: It doesn't show the most significant service-related thing you can do to a Prius, replace the hybrid battery! I just did that on mine on 5 June, and for 5 June my VIN reports:
    ENGINE MINOR,*OUTER DRIVE BELTS,*CABIN AIR FILTER,*FUEL SYSTEM SERVICE,MULTI PT INSPECTION
    Engine Minor? I don't think so!! This omission is extremely significant to anyone who wants to buy your car!
  8. JC91006
    16,764
    8,562
    They'll probably update it with the battery info after the core is logged as returned
  9. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    So how long does that take? Been 2 weeks...
  10. JC91006
    16,764
    8,562
    It normally takes 2 weeks
  11. Tideland Prius
    16,549
    lol. My experience was slightly different - The dealer pushed some of their own service and when I said no, it said "Customer declined recommended service".
    This is BS because if anything goes wrong and I need a warranty, Toyota or the dealer will see this crap typed it. It's so vague and sounded like I declined the Toyota service interval when it was really just one single item that the dealer pushed ahead.
    fotomoto and Raytheeagle like this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    So how do you get the record changed? Is that even possible?
  13. Tideland Prius
    16,549
    I'm not sure actually. I haven't asked since by the time I noticed it, the car was out of warranty.
    Raytheeagle likes this.
