Recommendation for Service - Indianapolis, IN area
Discussion in 'Gen 2 Prius Main Forum' started by viver45, Jun 19, 2018.
  1. viver45
    viver45 New Member
    Sheridan, Indiana
    Looking for recommendations on where to take our 2007 Prius. The VSC light, red ! check engine light came on along with a yellow !. Was able to pull to the side of the road and put car in park. Turned it off and back on. Lights were still on - tried to go into Drive would not move forward.
    So, not sure where to take car for service - I want someone reliable but someone who isn't going to charge an arm and a leg.
    52,006
    welcome!
    how many miles on her?
    viver45 likes this.
  3. viver45
    viver45 New Member
    Sheridan, Indiana
    Around 182,000
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Auto be Yours is a Prius shop south of you off of I-65 in Seymour:).
    Look the up and give em a call(y).
  5. viver45
    viver45 New Member
    Sheridan, Indiana
    Thanks - will consider them - just a little further than we want to go unless necessary!!!
  6. Cryptogram
    Cryptogram Junior Member
    17
    Indianapolis
    If you don't want to face a Toyota repair bill and can't find a trusted, qualified garage, I would have the fault codes read. I bought a blue tooth (ELM 327) on eBay and loaded a free app on my phone and can get real time diagnostic results and clear the codes. Carista is a simple and easy to use app. Another is Torque. It will give you a more in depth analysis. Often clearing codes will allow the car to restart and get you home.
    Good luck!
    #6 Cryptogram, Jun 21, 2018
    viver45 likes this.
  7. viver45
    viver45 New Member
    Sheridan, Indiana
    Thank you!!!
