Heart Transplant at 278,000 miles
Discussion in 'Gen 2 Prius Main Forum' started by SnT08Prius, Jun 22, 2018.
  1. SnT08Prius
    SnT08Prius Active Member
    158
    187
    Bozeman, Montana
    Well the day came that the minor miss became a major clatter and miss fire. Changed the injectors, plugs and coils to no avail.
    So off to the wreckers to find a second hand motor for cheap.
    7 days later and $800 the little Prius is back to work doing 45+ MPG. The donor motor had 130,000 miles on it and not burning oil yet :)
    SFO, chelvis, The Electric Me and 4 others like this.
  2. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    Bravo!:notworthy:
    Any pics of surgery? :-E
    edthefox5 and SnT08Prius like this.
  3. SnT08Prius
    158
    187
    Bozeman, Montana
    No... but I do plan to collect the motor in a few weeks to pull it down and see what broke in side.
    SFO likes this.
  4. bisco
    51,742
    who did the work? that's a great price.
    SnT08Prius likes this.
  5. SnT08Prius
    158
    187
    Bozeman, Montana
    Well... it was down town Phoenix! A wrecking yard. Not the best looking place, but they had all the tools needed. :)
    And the car is back on the road. Some places quoted $2,500 for second hand motor fitted.
  6. Patrick Wong
    18,200
    6,500
    A forklift is the wrecking yard's idea of a vehicle lift? Glad to hear they did a good job with the engine swap.
    Prodigyplace, hill and SnT08Prius like this.
  7. SnT08Prius
    158
    187
    Bozeman, Montana
    2 weeks out and the car is running great. not using much oil at all. Mid 40's MPG
    2,000 miles an looks like no issues for now!
  8. ITBland
    433
    278
    (y)Great news!
  9. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Mehn! I like setups like that. When you work in places like that, as I do sometimes, you become a "hard core".... Well, can't remember now.
    But sometiy, what amazes me is how people, or car owners, tend to EQUATE QUALITY SERVICE DELIVERY, TO DEALERSHIPS. Well, maybe because they've got AC systems, and you get to be served some hot coffee? OK, I get. Might be because of the WARRANTIES!?:D.
    As long as service is delivered satisfactorily, I won't bother with whtehyits a " clean"!!!!!! Place!
  10. Patrick Wong
    18,200
    6,500
    Did the salvage yard tell you the odometer reading of the car that was the source of the used motor?
  11. Mendel Leisk
    41,164
    From his first post.
    @SnT08Prius Is that your car or the donor car on the forklift? Surprise, Arizona? Not a cloud in the sky!
    Patrick Wong likes this.
  12. SnT08Prius
    158
    187
    Bozeman, Montana
    The car the motor came out of have 130k on the salvage sticker.
  13. SnT08Prius
    158
    187
    Bozeman, Montana
    The wife's car in the air.
    Don't think I have seen a Prius with more air time LOL :)
  14. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Raytheeagle likes this.
  15. SnT08Prius
    158
    187
    Bozeman, Montana
    Picked up the dead engine today from Star Auto in Phoenix. It's mounted on an engine stand with the rocker cover off.
    Pulled the spark plugs and No 2 was oily. The other 3 were all looking ok. I could not see any broken bits in the rocker gear or inside the ports.
    So it's head off next week after I get the balancer off. Better read up on how to do that and if I need a puller for it.
    Note: the replacement motor is not using any oil and getting very good economy. 12,000 miles on it now as the odo hits 290,000 miles.
  16. Mendel Leisk
    41,164
    Ok, you're following through on your postmortem plan; that's dedication. (y)
  17. ITBland
    433
    278
    Always loved a good horror movie--going to get some popcorn! :eek::giggle::D
    Congrats! (y)
  18. SnT08Prius
    158
    187
    Bozeman, Montana
    Progress so far.
    Fred_H and Raytheeagle like this.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Your motor looks pristine on the top end but usually blown piston wrist pin bearing from lack of oil.
    or the mains from same
    Usually piston #2 goes first for some reason. If you had kept driving it would have forcefully exited the side of the block. Exciting things happen when the piston falls off.
    Usually somewhere it saw an oil starvation event...threw a check engine light or a red triangle. if its Clakity clak its the piston bearing if it thud thud its the main.
    If you keep the oil at the full line that little motor can go 500,000 miles. Lots of taxi's do. Very well designed motor and trans. You have to go out of your way to kill it. May I hazard a guess its the wife's car?
    Look at the pistons carefully.
    #19 edthefox5, Aug 12, 2018
    TomB985 and SnT08Prius like this.
  20. ITBland
    433
    278
    Uh-oh:oops: Now THAT's a turn to the dark side!:confused:
