What is Total Load Capacity of 2010 Prius?
Discussion in 'Gen 3 Prius Technical Discussion' started by cycledrum, Jun 28, 2009.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yep. But, sometimes the other sources are helpful to get relative comparisons to other vehicles. After all, is one going to go to Chevy, Acura, Nissan, Ford, etc. dealers and look around at the load info on all the models there?
    By itself, ~8xx lbs. sounds low. But, with context after comparing with other similarly sized vehicles, across many brands, you'll find that it's not. Many small SUVs and "crossovers", have relatively low max load limits.
  2. Jolly Paul
    Jolly Paul Member
    162
    28
    I replaced the stock Toyota electrons with "I Can't Believe It's Not Electrons" brand of charge carrying subatomic particles for the added fuel efficiency. You can get them from Best Buy next to the Monster Cables.
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Please state your source - I have a little physics background, and your statements are well to the uneducated side. Replacing electrons - please...
  4. macman408
    1,179
    368
    You should instead try replacing your protons with positrons (antimatter electrons). They have the same charge as protons, but are roughly 1,000 times lighter, the same mass as an electron. You'd get far more benefit by replacing the protons than by even removing all electrons completely.
    There's a reason they're next to Monster Cables, you know - they're about as effective.
  5. compac
    compac PSU, Metallic Blue Ribbon
    52
    VA, Blue Ridge mtns
    Could I fill my tires w/ He?
    That could help?
    NOT IMO
