Loud noise when AC is on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Oct 11, 2017.
  1. Preeeus
    Preeeus Member
    258
    60
    When the AC is turned on, it makes a loud noise. Turning off the AC causes the noise to stop.
    Toyota diagnosed the sound as a bad AC compressor, so they replaced it. That fixed it for a while, but now the sound is happening again. Is the new AC compressor failing?
    Here is the video:
    the password is ' repair '.
    Thanks.
    Fostel likes this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    they probably didnt add oil to compressor when they replaced it or bad compressor to start
    Preeeus likes this.
  3. bisco
    52,386
    did they charge you?
    Preeeus likes this.
  4. Preeeus
    Preeeus Member
    258
    60
    No, they were kind and did not charge.
  5. bisco
    52,386
    they replaced a 7 year old $2,500. compressor for free? i guess you can't argue with that, but now you'll have to go back and ask what the sound is. are you getting cold air?
    Preeeus likes this.
  6. Preeeus
    Preeeus Member
    258
    60
    The AC compressor they replaced a year ago was, thankfully, covered under our extended warranty. The current one is covered for a couple more days under the 1-year parts warranty.
    The dealership that performed the original replacement identified the sound as coming from the AC compressor again. This time, however, they said the sound is normal. They brought out a similar model year Prius (a 2011... ours is 2010), and it did make a fairly similar sound. The weird thing is that ours was not making the sound before... or at least not nearly that loud.
    We are getting cold air.
    Given that the dealership claims the sound is normal, and we aren't experts to contradict them, we aren't sure what to do except live with it.
  7. Preeeus
    Preeeus Member
    258
    60
    Opinions/recommendations from others are welcome!
  8. bisco
    52,386
    find another 2010 to compare it to? does the dealer have any used gen 3's?
    Preeeus likes this.
  9. toilet
    toilet Junior Member
    karachi
    I have the same noise. I got the car in 2015. It's a 2012 Gen 3. I didn't notice the noise at first (which I feel I definitely would've noticed earlier had it existed) but in about early 2016, I noticed it but AC worked perfectly fine. It's June '18 now and the car makes the same exact noise and AC still cools and hasn't leaked (though I feel the cooling efficiency keeps fluctuating, especially in the past week, no idea why). That sound seems pretty normal then. Any thoughts on MAINTENANCE work I should do at this point to keep the AC at full blast? Is the AC drier replaceable on this? Should the compressor oil be changed even though there is NO leakage? Cabin filters are routinely swapped out.
    Fostel and Preeeus like this.
  10. stan kinaz
    stan kinaz Junior Member
    Las Vegas
    I replaced the fan assembly and no more noise. The fan on the driver's side stopped working.
  11. OptimusPriustus
    OptimusPriustus Active Member
    335
    142
    Finland
    Just few days back i noticed our Prius A/C make exactly same noise. I am not primary user so i am not sure how long this has been going on. Our other car (different brand) A/C made same noise several years and i always assumed it’s about to die but it just kept going. Then it finally gave up and A/C just stopped working. Compressor was replaced at dealership and to my great disappointment new compressor sound same. So Prius A/C making this sound i am going to do this: nothing:)
    chrisinator13 likes this.
