Firebrid: The Prius v Powered Hybrid Convertible
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Jul 4, 2017.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    What - is "EZ3 (future project)"? Looks like a Beemer of some sort.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Good plan(y).
    We just got our 4.3 kWh system up and running and it is great ;).
    Produces on average 28 kWh a day, which was sized just enough to sneak a Prime into the mix once our 2010 gets too long in the tooth:).
    Scoped out the z3 you’ll be using yet:whistle:?
    m.wynn and Bill the Engineer like this.
  3. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    My wife wants me to build her an all-electric BMW Z3 when the Firebrid is done.
    Haven't found the right Z3 yet. I need a creampuff with a blown engine. Once the new garage is up and running the search will be on!
    Bill the Engineer
  4. alanclarkeau
    7,045
    7,592
    I guess she saw the Royal Couple's E Type Jag and wants to outdo it? There was a report in the local news about a Rolls Royce Silver Shadow EV conversion here in Australia - not quite finished, but I'll be interested to see what range that land-barge gets.
    Rolls-Royce Silver Shadow gets conversion to electric; 'It's a little bit sacrilegious,' owner says - ABC News (Australian Broadcasting Corporation)
  5. Bill the Engineer
    1,048
    2,278
    467
    Judiciously applied duct tape to keep the car cover from shredding on sharp edges. :rolleyes:
    m.wynn, Raytheeagle and alanclarkeau like this.
  6. alanclarkeau
    7,045
    7,592
    Just spraypaint it now - Mythbusters would approve!!
  7. Bill the Engineer
    1,048
    2,278
    467
    Getting close to moving day!
    The Prius v parking brake assembly was installed in a temporary location and is functional. In the future it will need to be welded to the Firebird mounting bracket so that it will be in the correct position. I simply ran out of time.
    The rear wheels are back on the ground so that the car can be stopped when loading onto the trailer. Also the trunk lid is back on the car so that the car cover has something to rest on in the rear without flopping into the opening going down the road.
    Finally, I mounted the bike rack onto the trailer hitch so that the bikes don't need to take up space in the U-haul truck.
    A busy but productive weekday evening.
    Bill the Engineer
    #247 Bill the Engineer, Jun 26, 2018
  8. Bill the Engineer
    1,048
    2,278
    467
    On your mark...
    Bill the Engineer
    #248 Bill the Engineer, Jun 30, 2018
    Prodigyplace and Raytheeagle like this.
  9. Bill the Engineer
    1,048
    2,278
    467
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    My folks live in PA and it’s expected to be in the mid to high 90’s:eek:.
    It’ll be 100 out here today, but that’s not abnormal.
    Make sure to hydrate and take it easy as you move;).
    Your new gig does not have a moving company supplied:whistle:?
    Good luck and stay hydrated(y).
  11. Prodigyplace
    12,520
    11,740
    Central Virginia
    You asked in post 234 and it was answered in post 235.
    #251 Prodigyplace, Jun 30, 2018
    Raytheeagle likes this.
  12. Bill the Engineer
    1,048
    2,278
    467
    Get Set...
    Bill the Engineer
  13. Bill the Engineer
    1,048
    2,278
    467
    GO!!!
    Bill the Engineer
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Looks good and secure:).
    Safe travels(y).
    Bill the Engineer likes this.
  15. padroo
    padroo Senior Member
    2,763
    2,252
    I see the alternative transportation on the back of the Firebird, very green.:)
    Good luck on your travels.
  16. Fred_H
    Fred_H Misoversimplifier
    558
    482
    28
    Germany
    a rather complicated method to transport bicycles ;)
  17. Bill the Engineer
    1,048
    2,278
    467
    The Firebrid is safely tucked into its new temporary storage unit in Delaware awaiting the day when it can finally be moved to the planned heated garage at the yet-to-be-built house. All of the project parts, etc., are a couple of units away. Sadly, this means the project updates will be taking a break for about a year until that finally happens. Time to go back into planning mode!
    Bill the Engineer
  18. padroo
    2,763
    2,252
    Glad you made it OK. Life does seem to get in the way doesn't it. :)
  19. Bill the Engineer
    1,048
    2,278
    467
    The whole "project" took two more days than we planned, but all of the tasks are done. The remainder of the household will be Delaware residents by the end of the month!
    Bill the Engineer
    m.wynn, breakfast and Prodigyplace like this.
  20. bisco
    51,801
    all the best bill, stay in touch!(y)
