2017 Prius Prime turn w/ aftermarket turn signal mirrors
Discussion in 'Prime Accessories and Modifications' started by Insighter, Feb 24, 2018.
  1. sdhzlgl
    sdhzlgl Junior Member
    32
    montereypark
    2018 Camry's rear-view mirror turn signal. Can be modified on top of prius.
  2. randomwalk101
    randomwalk101 DYI'er
    532
    270
    texas
    Just buy the Avest. It’s a perfect fit and better function...and prob cheaper than OEMs. You will have to run wires anyways OEM or aftermarket.
  3. sdhzlgl
    32
    montereypark
    Is there this complete circuit diagram? I want to know the location of this plug because I have already purchased the turn signal and are ready to install it in the near future.
  4. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    I love this! Cheap mod and big impact!
    Gonna order this in the black chrome :X3:
    Weekend Project here I come
    Insighter likes this.
  5. Insighter
    Insighter Active Member
    409
    286
    SoCal
    My installer did mention that the included wiring instructions work, but that they are a bit overly-complicated. He said there are a lot of wires (I think he mentioned the dome light in particular) that the instructions would have you go deep into the car for when all of them (I'm pretty sure he said all of them) are available under the dash (so there's no need to disassemble more of the interior to tap them in more remote locations).
  6. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    It looks like it’ll be cake from looking at the eBay listing wires. It’s not the biggest wire harness but I’ll post my results :D
    Do you use the DRLs on it? So if you use the auto does it go on ?
  7. Insighter
    409
    286
    SoCal
    Yes, I have the DRLs on all the time (white, not blue).
  8. JDWays
    JDWays New Member
    Beaverton
    2020 Prius Prime
    Do you know if these will work for the prius XLE (Plus/Premium; without turn signal mirrors from factory)?
  9. quikslipper
    quikslipper Junior Member
    La Habra
    2018 Prius Prime
    I'm bound to get these. Still on the fence though because i dno't like dealing with electrical stuff esp on my car. I would rather have an expert do it. Any chance this is an easy DIY? Any updates as far as where to get these now?
  10. chickenhawk
    chickenhawk Member
    261
    95
    CA
    Did you run the puddle light wire to the dome light ? I picked up the LED signal lights.
