Grinding Noise while Gas/Brake [Car On Park]
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Micheal Wick, Jul 1, 2018.
  1. Micheal Wick
    Micheal Wick New Member
    Whittier, CA
    2016 Prius c
    Hi All,
    I really need help after going to Toyota Dealer & local mechanic.
    I hear a grinding Noise during different situations
    -Car is moving and I push the brake, at the end of the Push I hear the sound [if i push just a little bit i don't hear the sound, it has to be a heavy Push to slow down faster, but not like an immediate full stop to avoid an accident push][intermittent]
    -Turning the car on, when the gas engine kicks in. [now it turned into Always]
    -Car on park, Air Condition is on, Sound can be heard when the battery get low and gas engine kicks on.
    -Put the car on reverse,on releasing the brake, I hear the sound. [intermittent]
    I was able to record the sound
    Car on Park,Car is in Ready [turned on, EV light on, gas engine not started], When I push on the gas to kick the engine to start, you can hear the sound on second 4,11,18. [Sound is Always]
    The Dealer did a full CHECK, said I need to replace brake fluid and brake adjustment
    Local Mechanic checked my brakes and fluid, said its fine, he just adjusted my brake on the back and he claimed that the noise will go away after 2 days of driving, which doesn't make sense to me at all since the noise is really increasing over the course of the last month
    the noise is coming from near my feat that's where i placed the phone to record it, I feel like some gears are grinding. my personal opinion is that it has something do it with starting the gas engine and has nothing to do with the brakes
    car 2016 Prius C persona Series, 45K Miles, last oil change on 43K.
  2. Micheal Wick
    Whittier, CA
    2016 Prius c
    -after driving for around 10 min, made a full stop, put the car on park, released my feet from brakes, heard the noise
    if the car is moving, I never hear the sound if i am accelerating wither its in ECO zone or power zone. i only hear it with a heavy push to the brake [example : a push that can take my car from 40 to 20 mph in 2 seconds]
  3. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    Gotta be honest - it sounds like rusty brake rotors/drums. Possibly even a pad that has shifted ever so slightly (no biggie) and hitting the uber rusty party of your rotors. The Regen system does most of the slowing of your Prius (which is why brake pads last on these things forever) The pads on a Prius only engage if needed or at stops under 7mph or during hard braking (could be 5mph, but I think it's 7 for that low speed trip)
    I'm inclined to side with the Tech on this one.
  4. bisco
    51,524
    welcome!
    how many miles have you owned it for?
    at what mileage did the noise start?
  5. Micheal Wick
    Whittier, CA
    2016 Prius c
    Hi Bisco,
    I bought it on 42.5K mile 2 month ago, and on the first week I heard it like 2 times i didn't bother with it, but now it increased, Do you know what could it possibly be?
    the mechanic checked my rotors/drums, he said they are good, I can go to another mechanic to get them re-checked.
    the reason am saying i don't think its the brakes because I can hear the sound when the car on Park,EV and I press Gas to start the gas engine, i hear that grinding. am not an expert, but doesn't that rule out the brakes?
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I tend to agree with you... if you're not even touching the brakes and you're able to replicate it, that doesn't sound like brakes.
    Take it back to the mechanic and show him this exact example, if you're able to replicate it as such.
