Odd oil change technique - add half, start car?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mikepaul, Jul 25, 2004.
  1. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I had never seen anyone do this before, so I ran over to the guy changing my oil Saturday and pointed out he had only added half of my gallon jug of Amsoil before trying to start the car.
    The answer was: to get the filter to fill up with oil before adding the rest.
    I had believed up until now that adding all of the oil was important, and that the amount normally in the filter would get there fast enough to not hurt the engine by having the crankcase temporarily 'overfilled'.
    Does anyone else add half the oil, start the car for a moment, then add the rest?...
  2. jchu
    jchu New Member
    1,063
    Nampa, ID
    Doing my own oil changes for years, I would add 3 quarts then start the engine to fill the filter first. I did this, not to avoid temporary overfill, but to avoid ending up with overfill when I added the last bits of oil. By filling the filter first, I could use the dip stick accurately to complete the oil change.
  3. peart75
    peart75 New Member
    104
    san diego
    when changing my own oil i fill the filter about 1/2-2/3 full . i don't think starting the car to do this process would be such a good idea.
    -drew
  4. 8AA
    8AA Active Member
    550
    62
    Maryland
    I know the main reason for starting the car after an oil change is to fill the filter, but it's also to make sure the filter is seated properly. How do you do this in a Prius? Assuming that the car is already warm, if you press the start button, isn't it possible that the ICE will just sit there? Do you turn on the A/C and other accessories to try to drain the battery? Do you just sit there and wait?
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i usually just fill to the line, then drive a block or two. then remeasure and refill to the line. when filling the filter, you are talking a cup or two.
  6. jamarimutt
    jamarimutt New Member
    985
    I add 3.5 quarts, drive the car around the block, measure the level, and add slowly until reaching the full mark.
  7. richard schumacher
    7,664
    1,046
    United States
    Lazy/non-anal people will note that there's no need to completely fill the system. Anywhere between ADD and FULL is fine.
  8. mikepaul
    1,763
    Columbia, SC
    Well, at least some other people do it the way I saw it done.
    One thing I noticed when I got home is, I'll have to keep an eye on the tires. At 5,000 miles they were all still up near the original setting of 42/40psi, but this time they were all in the mid 30's. From now on, if I don't feel a bump when I ride over a piece of paper, I'll have to stop and pump them up again...
  9. Frank Hudon
    Frank Hudon Senior Member
    4,147
    ok just for a laugh and I'll date myself, back in the early 70's I was working in a GM dealership in Northern British Columbia and the lube dept called me in, I was in the tune-up dept, and said they just got chewed out by a customer with a mid 60's Buick when they changed his oil because the motor had an oil filler cap on both valve covers and they put all the oil in one, they tried to get me to explain to the guy that it was ok, I had to remind him the car had only one oil pan and there was only one oil pump and all the oil circulated thru the entire engine, he was still muttering when he left. He wanted the oil put in both sides. Normlly I put in 3 and run it and then top it off at the full mark.
