[Help] Prius revving while driving or braking 2010, 195k miles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mindfk, Jul 6, 2018.
  1. mindfk
    mindfk Junior Member
    United States
    Yesterday my Prius started acting in a very unusual way while driving home from work, at first during low speed driving it would engage the engine in weird situations as if it was charging a battery when it is depleted, that would cause a jerk and the engine would rev up to keep up with the load. Few miles down the road, on an interstate it then turned into a full blown uncontrolled revving while driving, braking or in neutral while coasting - like it wanted to keep charging the battery even if the battery was full full - as per the display.
    I just got a check engine light but it's the standard lean condition p0171...no exactly what i expected.
    Also, when i'm stuck in traffic it would dip rpms's to the point where everything sounds like a cold start knock and then it either corrects itself or the engine dies like it normally does when EV takes over.
    See video below from some highway over-revving action:
    https://photos.app.goo.gl/eLELaZSoL6Jnoq6R8
    Any ideas?
  2. JC91006
    JC91006 Senior Member
    16,748
    8,554
    Try cleaning your throttle body and MAF SENSOR. While you're in there, check the air filter
  3. mindfk
    United States
    Air filter is good, I replaced it within last 10k miles; I will do MAF and throttle first and report back.
  4. JC91006
    16,748
    8,554
    after cleaning the 2, you should disconnect your 12v negative for a minute to reset the car. Or else it might run really rough
    If this doesn't cure it, then you might have to do an EGR circuit cleaning afterwards.....which is a good 4 to 5 hours of work
    danlatu, m.wynn and Raytheeagle like this.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Get access to a scan tool and check your fuel trims. See if your lean condition is most prevalent at idle or at 2500 rpm. My guess is that at your mileage, the fuel pump is probably the culprit.
    iPhone ? Pro
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    4 to 5 hours with the proper assistance ;).
    First time doing the job (without a spare egr cooler) will be a solid 8-9 hours.
    Good luck to te OP and keep us posted (y).
    JC91006 and m.wynn like this.
  7. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    check your 12v battery
    dame3780 likes this.
  8. JC91006
    16,748
    8,554
    I'm not looking forward to doing mine lol
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I’ll be in your neck of the woods the week after thanksgiving :).
    That Friday we usually do a half day in Disneyland, so always looking for a way to get away;).
    A week there is more than enough :sick:.
    m.wynn likes this.
  10. JC91006
    16,748
    8,554
    We'll go out for a drink, forget fixing cars on vacation
  11. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Sounds like a plan :).
    I’d like to see your setup;).
    If it comes with beverages, I’m good with that too(y).
    #11 Raytheeagle, Jul 6, 2018
    m.wynn and JC91006 like this.
  12. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Check oil level
    If it is low, you are in big trouble
  13. mindfk
    United States
    I did a catch can mod a while ago; after unbolting the intake i discovered that the nipple came off the manifold; you can imagine how surprised I was to see this. I cleaned the throttle and MAF anyways - took it for a spin and it does not surge/stutter/knock at low rpm which is good. Revving while driving/coasting did not go away yet - that's probably because I did not disconnect the battery to reset the ECU and it's still correcting for a gaping 1/4in hole that I had from catch can hose adapter. I will reset asap.
    After around 150k miles my my Prius became a thirsty SOB; it burns around a quart every 4.5k miles, I change oil every 8-9k using 0w20. I plan to keep adding oil until this thing blows up which is probably within the next 50k miles... or max 2 years... which is good enough for me.
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    A quart every 4.5 k miles isn’t bad at all;).
    Ever consider clubbing up in oil viscosity?
    At 195 k miles, your egr circuit is plugged with carbon deposits :(.
    I’d look for a window of time to clean it before the head gasket gives way;).
    m.wynn and tankyuong like this.
