  1. orenji
    orenji Senior Member
    5,887
    3,488
    Who da lucky player with all the dough bro?!
  2. orenji
    5,887
    3,488
    You had to go and buy a Land Cruiser!!
  3. MPGRaja
    MPGRaja Senior Member
    472
    1,682
    Corona
    You got the wrong guy lol :LOL:
    orenji likes this.
  4. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    You'll see.
    Burna J likes this.
  5. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Same! I inquired but its pricey... Just to get it here is almost as much as the spoiler lol
  6. orenji
    5,887
    3,488
    Ha okay secret stuff!
  7. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    im gonna try to make my own relay for the gvif cable in my car which shuts off the video input to the nav screen so i can either send in a different AV signal thru the gvif or use Car-solutions.com relay switch box to add a second AV input in the L47 input i think its called... (the 20 pin) (which for me will be a 360 camera). But yea, anyone here who knows what relay could be used? and if there is any gvif wires i can by seperatly as extensions?
    This is my plan, since the gvif got first priority (rear cam and parking assistant), when the relay cuts off the signal the 20 pin (where the rear camera for the cars without rear camera is connected) will in my theory open up for the 20 pin to be first priority. Which would allow a second AV input to be plugged in. [​IMG]
  8. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    Wow. Is it that complicated if you don't have parking assist? To my relatively untrained eye, that's a really overly-complicated way for Toyota to have set up video input for the Nav system.
    I've been wanting to replace the off-center rear camera, put in front bumper cameras for parking and blind-spot cameras for highway travel since I got this car. Sounds like I'll be better off to just put in a separate monitor or two with a switch box rather than mess with the Nav display.
  9. MagnusAG99
    673
    521
    Norway
    with the non-parking assistant version it goes thru the L47 input or whatever the heck its called... So for u (if u dont have the parking assist) its easy peasy to add a front camera or even birdseye view 360 camera. Get in contact with car-solutions.com and they`ll help u find the relay box u need to make the second AV input to ur unit. Its just a relay box basically, u get extensions to ur already existing cables in the back of the unit, then the relay switches between front and rear cam (OEM and/or aftermarket) via the "mode" button on the steering wheel and with "seek +" and "seek -" u change which camera u want to be shown on the screen. Did it on my moms 2016 auris, very easy to install both front camera in the toyota emblem and the box inside the car, soon changing the front cam out for a 360 camera. Im also gonna add front bumper cameras on it, so it can show the blind spots in the front, its quite a long car so it would be worth installing it. I think i can both give her a 360 cam and blind spot cameras on both sides at the front while keeping the original rear cam aswell. Since the rear camera is OEM, its 2 AV inputs open, one that im gonna use for 360 and another i will use for front blind spot cameras (simulair to BMW`s)
    And toyota have made it that hard for us with parking assist sadly... It goes thru a completely different cable which is the gvif, it got first priority for the screen no matter what by some incredibly dumb reason only toyota could answer (they most likely got no valid answer at all). But yea.. for me it is that complicated, i have to find a second relay for the gvif so i can turn that shiz of so the front camera gets to be shown on the screen.
  10. BlkGenIII
    BlkGenIII Active Member
    86
    259
    SoCal
    Stopped by Hybrid Pit today for routine maintenance. Oil change, tires rotated, everything checked over. Doing somewhere around 4000 miles a month right now... this interval came up a little quick this time
  11. MagnusAG99
    673
    521
    Norway
    4000 miles??? where the flying hell do u drive everyday? LOL.I filled my tank 3 weeks ago up to like 4/5 tank (580km) and im down to 350km now lol. I dont drive that far.. but u... my god?
  12. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    I thought mine was bad at ~3K/month :LOL:
  13. m3pare
    679
    1,818
    SoCal (626)
    Delete
    apt5020 likes this.
  14. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    look like he need to get rear bumper mod!
    m3pare likes this.
  15. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    20180713_130521.jpg Special delivery 20180713_130421.jpg 20180713_130011.jpg
    #16235 Nopho4u, Jul 13, 2018
  16. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    sfv41901 likes this.
  17. Nopho4u
    1,007
    2,061
    Socal son
    U got it dad
    Accordlayingkit likes this.
  18. potatoesLOL
    potatoesLOL Active Member
    145
    413
    Downtown Los Angeles
    Worth the wait, so clean
    sfv41901 and Accordlayingkit like this.
  19. Prius7Prime
    Prius7Prime Junior Member
    58
    Long Beach
    2012 Prius Alpha
  20. Nopho4u
    1,007
    2,061
    Socal son
    20180713_173910_HDR.jpg preview. Gotta make some adjustments
