What does your oil look like after 5000 miles?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Jul 11, 2018.
  1. Preeeus
    Preeeus Member
    258
    60
    We're curious... what does your engine oil look like (on the dipstick) after 5000 miles since your last oil change?
    Is it still clear, or is it fairly dark?
    #1 Preeeus, Jul 11, 2018
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I don't have a prius anymore, but I've owned 3 Prii in the past. The oil color was always fairly dark. Definitely not pitch black, more of a darker brown
    Preeeus likes this.
  3. bisco
    51,811
    mine is so clear, i can't see it on the dipstick.
    qettyz and Preeeus like this.
  4. padroo
    padroo Senior Member
    2,763
    2,252
    Mine always looked clear even at 100,000 miles and never used any either.
    Preeeus likes this.
  5. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    dark when it comes out of the oil pan
    Preeeus likes this.
  6. Mendel Leisk
    41,255
    Good point, and I agree. The oil on the dipstick when I drain ours (after maybe 4~5000 kms only) still looks like new, but a jarful of the stuff tells a different tale: black as ink.
    On the other hand, with a couple of conventional cars I also change the oil on, it looks black as ink on the dipstick, lol. That's typically with around 8~9000 kms though.
    Preeeus likes this.
  7. orenji
    orenji Senior Member
    5,887
    3,488
    There's supposed to be oil on the dip stick? :)
  8. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Here’s a pic of our 2010 with 182 k miles on it (2500 miles on this oil):
    Not too bad(y).
    bisco, m.wynn, Grit and 3 others like this.
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Hope Mendel sees this photo, he said his oil after 5k looks as clear as it was put in when new. Obviously it was an overstatement by him :p
    Raytheeagle likes this.
  10. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    NO WAY!!!
  11. Mendel Leisk
    41,255
    Huh? Maybe on the dipstick, definitely not the drained oil. I've posted this before. New, Toyota 0W20:
    And drained, after maybe 4000~5000 kilometers:
    mtl, icyrius, bisco and 3 others like this.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Mine always coffee brown dark, & not oil burning either. dont even believe people when they say after 12000 or 15000 miles its still clear as it was first dumped in, i want real pictures before and after. the wine is soo kicking in now
  13. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    Clear, with a light yellowish tan tint, as seen on the dipstick. Before about 2000 miles, it's so clear it's hard to see.
  14. bisco
    51,811
    look like a couple of craft brews!(y)
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    That must be his retirement hobby:whistle:.
  16. OptimusPriustus
    OptimusPriustus Active Member
    332
    141
    Finland
    Rhetorical question, right? Gen 3 Prius has automatic oil renewal system (special piston rings allowing oil to escape) and in my case it’s 10% per 1000km:ROFLMAO:
  17. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    My oil renewal system isn't working so well. How can I fix it?
  18. OptimusPriustus
    332
    141
    Finland
    Extend OCI and it’ll activate(y)
