Best Deceleration Rate?
Discussion in 'Gen 2 Prius Main Forum' started by metalnut, Aug 6, 2006.
  1. metalnut
    metalnut New Member
    Hello all, I'm brand spankin new here, and I've done some very illuminating research on this site, for which I must thank all the knowledgable generous people :). And since I don't have an owner's manual (I bought a salvaged Prius, manual gone) I don't have that knowledge base (though I did download the skimpy manual offered online). Here's a question: I've read that regenerative braking conserves the brake pads (duh), but I was wondering what is the optimal rate of deceleration, or perhaps the "threshold" rate that converts most energy to the electric motor, with no or almost no brake-pad use? I timed a stop from 40 MPH, and at a "normal" or moderate rate of deceleration, it took about 13 seconds to stop, meaning I decelerated at about 3 MPH per second. How much of the kinetic energy of the car was recaptured at this rate? Thanks!
  2. Sufferin' Prius Envy
    3,998
    Hi metalnut,
    Welcome to PriusChat . . . fellow Sacramentan! Thank for purchasing a Prius and helping Sacramento maintain its standing as the #2 spot in the USA for Prii per capita! Maybe we can catch the Bay Area. :D
    http://priuschat.com/index.php?s=&showtopi...ndpost&p=254213
    The correct answer to your question is: For maximum fuel efficiency, it is best not to brake or regen. ;)
    It is best to glide as much as you can (or as much as you can stand, or the drivers behind you can stand :angry: ) and come to as slow and steady of a stop as you can with minimum use of of the brakes or regen.
    The sooner you let off the gas and electric propulsion and go into glide mode (no arrows on the MFD), the less energy you will waste in your travels from point A to B.
    Only a small percent of the regeneration energy makes it into the batteries. And then, even more energy is wasted converting that battery voltage back to wheel motion. The Prius will never recapture all of that energy, so it is best not to waste it on braking and regenerating in the first place.
    If you must step on the brake pedal to stop . . . and most of us do :p . . . “a gentle, but firm push on the brake pedal†is best for efficient regen braking.
    This link will take you to the information you are looking for . . . if you must use the brakes.
    http://vassfamily.net/ToyotaPrius/CAN/brindex.html
  3. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    Wayne Brown did extensive testing to answer this question. You can find the relevant posts in the yahoo 2004-prius group. I think his handle is mwbueno.
    I seem to remember that the HV battery can take up to 20 Amps. A bit of math would tell you the maximum rate that kinetic energy that can be taken up.
    Or, if you are the qualitative type: as slow as smart driving allows ;)
    As Patrick says, don't brake for regen sake, but if you know you have to brake, start early.
    Lastly, I do not brake with constant pressure. If traffic allows, I start *very* gently, and from about 20 mph and down, gently increase the brake pressure to fairly firm by the time I have stopped. I think I am gaining three things this way: one, at higher speeds the car bleeds off much more kinetic energy per mph/sec drop, and I don't want to exceed the battery's Amp capacity; two, there is a slight jolt at very low speeds when the wheel brakes kick in that I find annoying, and this technique blurs it; and lastly, the rotors have a tendency to rust from lack of use, so I try to heat them up below 10 mph or so, when regen is pretty much nil anyway.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    You stirred a pot that has more gunk at the bottom than you can imagine!
    Do look at the links provided above...it'll give you some base knowledge to help you out.
    There are 2 schools of thought here in general...I'm in a minor one (but, of course, I think I have the best answer).
    The maximum energy that can be regenerated from a given speed is accomplished with a regeneration rate of ~ -60amps. This has been confirmed by both Attilla and Wayne Brown as well as others in Japan. I consider that a reliable number. Those of us with CAN-View and other monitoring equipment can accomplish this and have a good sense of just how firmly one must brake to achieve it.
    The second, my, school of though here is more like Eric described above...maximize the anticipatory driving, gliding to a stop and avoiding, when safe and possible, the use of the brakes at all. Even though overall regeneration will be less, overall energy use will be less with a net gain in FE.
    The example I tend to use is to start with the car going 50mph 1 mile from a mandatory stop. If I back off the gas when I see I'll have to stop and begin gliding I'll burn no more gas, use very little electicity, and probably be able to regenerate all I do use by the time I have to stop.
    Same example if one intends to use the 60amp braking method it will be necessary to continue powered motivation for another 3/4 mile before you begin braking. Regeneration will be much better, but net energy will be lost instead of preserved as in the first case.
    Final point. There are several things that can cause you to get little or no regen braking and go immediately to friction brakes.
    1)Sudden brisk application of the brakes (even if you're not braking hard) will be interpeted as emergency braking and skip regen and go straight to friction.
    2)Hard braking--likewise interpreted as emergency braking
    3)Hitting moderate bumps while regenerative braking. This seems to be a function of the Traction contol also interpreting as an emergency situation so the friction brakes kick in for more solid/sure braking. Unfortunately it's overly sensitive, IMO, and even small firm bumps will cause it to drop out. On my usual commute I know where most of those bumps are (just seems in the pavement in most cases) and I take my foot off the brake completely just before those and gently reapply aftert he bump to be able to get maximum regeneration.
    I know that's a lot, but, as I said, it's a complicated issue.
  5. metalnut
    metalnut New Member
    Wow, fabulous stuff, thanks so much Sufferin' and Efusco and Eric! And its the kind of nuts-and-bolts operational stuff I can only get from seasoned Priists. I have geen gliding whenever I can after learning about it here, and it seems logical that gliding is a more efficient technique than regen braking, when traffic conditions allow it. I just wish Toyota had designed the system to have no arrows up to 45 MPH or so, because once I start coasting at 40 and slowing to 35, 33 MPH, I'm too slow for traffic. I've been trying to glide below speeds of 50 lately, and it seems to be the same except for the fact that I have arrows coming from the battery to the EM, to the wheels. What's happening at this point? The car decides I need a little extra juice to glide at that speed? I also see at least $137 profit to be made to the first person who can design a set of small mirrors to reflect the computer image to a point directly in front of me so I can keep my eyes on traffic. Its a bit distracting looking over at the computer, but I need to know when I'm gliding!
  6. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(metalnut @ Aug 6 2006, 11:42 AM) [snapback]298629[/snapback]</div>
    Over 41mph the ICE is spinning constantly. And the threshold for fuel flow/ICE running is very low. Achieving a 'no arrows' condition is very very difficult. During the arrows from batt. to wheels mode you're using a minimum of about 12 amps...anything over about 7 amps draw shows an arrow on the mfd (gliding is typically 3-7 amps depending upon your speed and how you're feathering the accelerator).
    There's not a huge benefit to pulse/glide over 41mph, I don't even try except on downhills I like to encourage a glide-like/hyperstealth state rather than allow regen and use the speed and momentum to carry me up the next incline as far as possible.
  7. fphinney
    fphinney Member
    234
    Walnut Creek CA
    <div class='quotetop'>QUOTE(metalnut @ Aug 6 2006, 01:15 AM) [snapback]298555[/snapback]</div>
    I ran across a web site ( http://privatenrg.com/#100kBrakePads ) where a guy had the personal experience of the SURPRISINGLY SMALL AMOUNT of front brake pad wear.
    His words, "At 100,520 miles, I literally could not measure any wear on these pads with my metal mm ruler. I know there has to be some wear but, it appears that I will have to remove the pads and use a pair of calipers to measure such a small amount. This is pretty incredible!"
    This tells me that the regenerative brake system conserves pads like the dickens! It feels like you are actually using up brake pads, when stepping on the pedal. But apparently you are mostly - - efficiently recharging the battery!
  8. EricGo
    EricGo New Member
    1,805
    Frank, you happened upon the web site on one of the most brilliant and knowledgeable Prius owners in the US: Wayne Brown. His website is a cornucopia of things Prius. His yahoo handle, as I wrote above, is mwbueno.
    A modest bow before entering his domain would be reasonable ;)
  9. tmgrl3
    tmgrl3 Member
    315
    I think I am way over my head here until I read back more of this and check out the other website...
    So....if I am coasting down a long hill which will end most likely in a stop sign or red light....do I keep coasting even though I am picking up speed and don't have another hill to climb when I reach the bottom??
    I hit the top at around 20-30 mph...then pick up lots of speech on way down...so I am way into 40s...(above slimit!)...and begin breaking toward the end? I thought that the coasting was giving me better mpg, and that it was better to brake nearer the end as needed...or should I be braking little bits on the way down?
    Certainly, if I have another hill to climb and can use some of the speed generated to assist the coming climb. These are all local hills in my neighborhood, but many are long and down or short and steep down...and reverse is true on upside. ....and
    I only drive short distances at a time in my area...5-15 minutes....
    terri
  10. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(terri @ Aug 6 2006, 06:43 PM) [snapback]298761[/snapback]</div>
    Terri,
    I think that's a good question and not one I have a ready answer for that I'm confident is the 'best'. But I'll tell you what I do and why.
    If I have a hill that I will have to stop at the bottom I slow as much as possible before cresting said hill...nothing ridiculous, but I certainly don't want to carry any unnecessary excess speed over the top if I'm just gonna stop at the bottom anyway.
    I apply very gentle brakes to avoid exceeding 40mph if possible so to prevent the ICE from spinning up (that takes power from the battery). At around 1/2 way down I start increasing the braking to try to get b/w 40-80 amps breaking--obviously this braking point varies depending upon the grade of the hill and such. I then feather the braking so that I stop with steady brake pressure right at my anticipated stopping point.
    NOW, if there is a line of cars at the stop sign I begin my firmer braking earlier so that hopefully I don't have to stop until the other cars have cleared the stop sign...obviously this isn't always possible, but if there are only 1-2 cars and the hill is long enough you don't want to have to stop more than once.
    On very long hills I do let the speed build then brake later much as described above, esp. when there are other cars behind me.
  11. whodat
    whodat Member
    117
    Aptos, CA
    I think the advice provided by efusco is probably very good. I would add one other thing. I believe around 7 or 8 mph the disc brakes kick in so I usually try to keep my braking and speed above 10mph if I am descending down a hill. I live near a hill that has little traffic so I can experiment with speed, but unfortunately I don't have CAN--VIEWER in my 2006 Prius.
    <div class='quotetop'>QUOTE(efusco @ Aug 6 2006, 07:01 PM) [snapback]298812[/snapback]</div>
  12. Sufferin' Prius Envy
    3,998
    But, if that downhill run happens to be a 55 mile, 4,775 foot decline (Touloumne Meadows to the Yosemite Valley floor) . . . lightly riding the brakes, gliding, and EVing in the appropriate places has its benefits too. :D
    http://priuschat.com/index.php?s=&showtopi...ndpost&p=276244
  13. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    If you're at 50 mph and seeing arrows battery --> motor --> wheels,
    that's "warp-stealth". Learn how to get into that state and hold
    it, because it's an important contributor to good MPG in the mid-
    speed range.
    The best way to regulate regen braking force is being able to see
    your battery current, via can-view or something else that can pull
    it digitally off the bus, or an analog rig tapped into the battery
    box current sensor. I find that 50 - 60 amps seems fairly optimal
    too -- healthy regen, but not going all the way up to 100A to avoid
    a little more ohmic heating in the pack and wires, etc.
    _H*
  14. tmgrl3
    tmgrl3 Member
    315
    Thanks, Evan!!
    Your answer pretty much covered the way I have been using the "coasting" to go downhill more and more.
    Some of my hills are shorter and steeper and I know that if I have too much speed going into them, I will pick up way too much speed for my sedate wooded community...LOL...like high 40s.
    So...I have been slowing slightly with easy braking as I near a hill and then coast (all green arrows going down) braking slightly as I pick up too much speed.
    I do try to watch the lights ahead, now, too and sometimes I am able to stay in coast mode until the light changes and keep on going.
    We really have a very hilly area near the northern shore of Long Island...especially blocks from the beach where I live.
    Also, I noticed since yesterday, that I started out on my second tank of gas at 60 mpg...because I could actually get into "stealth" mode (Is that the same as "deadscreen"...i.e. no arrows) and I could use the downhills to coast. Short trip home, only 5-7 minutes...then I got to my own neighborhood and had some steep ups and quick downs so...
    by the time I got home I was at 41 mpg...
    This morning I had to dash out to doctor (although I am now trying to bunch my errands so the ICE stays warmed up) and I had mostly "climbing...although to look at the road, one wouldn't think so...steady but even pressure to even keep at 30-35 mph.
    By time I got to the doctor, I had dropped to 31 mpg....BUT
    on the way home, the hills worked for me, and when I shut the car off, I had two green cars on the energy consumption screen (is 4 the max?)
    and my mpt was near 42 mpg again...so I will learn my neighborhood.
    It definitely seems to my advantage though to not accelerate "briskly" up the hills as I have seen mentioned elsewhere...as nice steady, not slow acceleration works better....
    Also, I can deadscreen under 30 mph....some of the time I am all electric (all yellow arrows)...and can deadscreen for short spurts.
    Can I read out the braking amps??? Don't know if that's something extra?
    I do use the lighter braking, though, on the way down hills to avoid excessive speed build-up especially when I am facing a sure stop and because it would take me way over speed limit in my area.
    I was going to take the car into Toyota because my first tank averaged out at 31 mpg calculated, 32.8 on MFD. But I did need to have better mpg toward fill-up, in order to bring that first part of the tank that was at 25 mpg up to the 31-32 range.
    Definitely with the hills, a rather even, steady pacing, using the downhill slopes and a nice steady climb to get to place where I can go into stealthmode for even a little bit, seems to be what will work for me.
    I will never be driving this car for any distance on a highway....or rarely......
    Thanks again, Evan....
    I am learning so much here at the forums.
    terri
