I'm guessing you could run the PHV on the ICE only?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Aboli, Jul 12, 2018.
  1. Aboli
    Aboli Junior Member
    TP HCM
    I would guess that you could run the PHV on the ICE only. what if you didn't have electricity for a week (act of nature) but still had to run errands?
    this is the downfall of all electric vehicles and having it as your only driver, you could be screwed if you don't have electrical to plug in your car.
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    You're right. Running on ICE for weeks on end does not hurt anything. Almost any Plug-in on the car lot has been sitting there, maybe for weeks, without being charged.
  3. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Yes, it will function as a normal Prius if you don't plug it in.
  4. Mendel Leisk
    41,894
    In other words, it'll still be running some of the time with the engine off, and engine off at red lights. I believe due to the larger battery it'll come out slightly ahead of a regular Prius for mpg, under the same driving condtions.
  5. bisco
    52,383
    why would someone buy an all electric vehicle if they didn't have electricity to plug in their car?(n)
  6. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Well, it operates as a"super" hybrid that never needs to "spill" extra charge on a long downhill coast.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    You get TERRIBLE gas mileage. LOL! I ran the last tank without plugging in just as an experiment. After driving 441 miles, I put 7.904 gallons in the tank for a calculated 55.8 mpg. (58 mpg on the HSI) Previous tank was 117.4 mpg (125 on the HSI). ;)
