Fuel Filling Problem
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by eric1234, Feb 6, 2017.
  1. bisco
    48,996
    did you open the door and leave for half an hour before coming back to fuel up?
    RCO likes this.
  2. padroo
    padroo Senior Member
    2,763
    2,250
    Maybe he went inside to buy a lottery ticket, a pack of Camels and a large coffee.:D
    Starship16, RCO and bisco like this.
  3. postwhistle
    postwhistle Junior Member
    Toronto
    Technology
    No, the second bullet...
  4. bisco
    48,996
    interesting, thanks!
  5. postwhistle
    Toronto
    Technology
    Then again, now that weed is legal up here the situation in the first bullet might become more frequent ;)
  6. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    When I received my car there was a big yellow tag on the wiper control with that warning too.
    RCO likes this.
  7. eluo
    eluo Member
    98
    63
    Commack, NY
    This just happened to me the other day with my Prime. I pressed Open Fuel Door and the door opened and then closed on me. I had to press the Open Fuel Door the 2nd time but I'm guessing that 2nd time didn't open the fuel vapor recovery valve. Without knowing about this issue, I tried refueling on a near empty tank and the pump just kept clicking. Then the gas poured out over onto the side of the car :(. I had to press the Open Fuel Door the 3rd time for my Prime to take gas.
    Tip - I heard that you shouldn't wipe the gas off the paint as gas will weaken the paint and wiping it will scuff the clear coat. Just let it dry and wash away the residue after.
    krmcg and Mendel Leisk like this.
  8. Prodigyplace
    11,696
    11,317
    Central Virginia
    If the valve did not open, it sounds like a bug that needs to be fixed. Did the display say the car was ready to refuel?
    RCO likes this.
  9. Mendel Leisk
    38,253
    Toyota has come up with a design to reduce emissions, and as a consequence owners are sometimes spilling copious amounts of gas down the side of the car? The EPA or whoever should be interested.
    RCO likes this.
  10. Jon Watkins
    Jon Watkins Active Member
    117
    109
    Bluffton SC
    Had the 17 3 in for the free 10k check today so had them replace the spring from the TSB while it was there. I’ve never experienced a problem but why not get it done while it was there. Called last week to get the spring ordered...it was a major pita convincing the assigned service advisor to order it.
    I can’t tell any difference in the way the fuel filler door opens. If anything it doesn’t seem to open as far with just the spring.
    RCO likes this.
  11. Starship16
    Starship16 Senior Member
    1,348
    1,453
    Beach Christmas
    :eek:
    Negative!! Immediately pour a bottle of water on it to wash off that gas. Been there, done that! :ROFLMAO: Do not allow it to dry on the paint! And then re-wax your fender.
    #51 Starship16, Aug 20, 2018
  12. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    The only fuel filling problem I have is the damn cost of the stuff here in the UK, £1.44 GBP for a litre of premium, that equates to $6.73 USD per US gallon.:mad:
    Dscycler, RCO and Prodigyplace like this.
  13. Mendel Leisk
    38,253
    Our (regular) gas is currently $1.44 as well, but CDN dollars, lol. Converts to 0.95 Euros right now. Still, why buy premium; Toyota recommends regular.
    RCO likes this.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Less ethanol in premium over here, although I do use regular more often than not.
  15. Prodigyplace
    11,696
    11,317
    Central Virginia
    If I recall correctly, I bought some ethanol-free gasoline last weekend for our garden equipment at $3.25 per US gallon, which is close to 4 L.
    kithmo and RCO like this.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
  17. Prodigyplace
    11,696
    11,317
    Central Virginia
    The normal 10% ethanol here is $2.50 per US gallon at the Mobil station I normally use.
  18. Mendel Leisk
    38,253
    Premium here also has less (or no) ethanol. I tried it once or twice, did not see much difference. Did fillup up the coast in a small town once, with Chevron regular, and got superlative mpg on that tank; I suspect it was ethanol-free. Maybe ethanol-free regular is the holy grail?
    See yesterday regular's up to $1.51 per liter.
    kithmo likes this.
  19. Prodigyplace
    11,696
    11,317
    Central Virginia
    We use ethanol-free mainly for our old garden tractor. Although it is a 1970, the engine design dates back to the 1940's
    (not my tractor)
    jerrymildred and Mendel Leisk like this.
  20. Mendel Leisk
    38,253
    That's a very pretty machine. (y)
    Prodigyplace likes this.
