ProClip is now available for the C!
Discussion in 'Prius c Accessories and Modifications' started by Nic Lechner, Jul 3, 2012.
  1. Nic Lechner
    Nic Lechner Junior Member
    65
    Sacramento Ca
    I emailed ProClip a few weeks back and asked when the C would have a clip. Just got an email from them today saying it was ready to order.
    http://www.proclipusa.com/854784.aspx
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Do don't really think this will work, do you?
  3. Nic Lechner
    65
    Sacramento Ca
    What do you mean?
  4. Nic Lechner
    65
    Sacramento Ca
  5. trenda
    trenda New Member
    I got the same email and ordered mine today. $64.98 to hold the Nokia N8. I have no worries since the product has a great reviews from Nokia users.
  6. ufourya
    ufourya We the People
    1,258
    336
    42
    I found a bit of plastic in my garage, painted it black with some left-over paint and stuck on a a few pieces of 3m dual lock. Moumted the plastic to the dash in front of the vent with its base resting on the little ledge at the base of said vent. Then mounted my el cheapo nav to the plastic. Total cost ... less than a dollar. (Not counting the nuvi.) IMG_3219 (800x397).jpg
    ftl likes this.
  7. Nic Lechner
    65
    Sacramento Ca
    ^ That is awesome!
  8. Nic Lechner
    65
    Sacramento Ca
    Did you get your Proclip? I just installed mine today.
  9. secondspassed
    secondspassed Member
    112
    26
    Corona, CA
    Post some pics!
  10. Nic Lechner
    65
    Sacramento Ca
  11. daboy
    daboy Junior Member
    51
  12. PriusCinFL
    PriusCinFL Junior Member
    I don't see this as a good solution for two reasons.
    First, I held my Samsung Galaxy S III in the position shown just above the warning signal switch and it blocks the view of the right display with all the warning lights etc.
    Second, it blocks part of the vent. I live in southwest Florida and need the air conditioner most of the year. Often I have it blowing on me at a slow speed for the wind chill effect - especially because my partner gets cold easily. Having it blow on me means I can set the thermostat warmer so that she is also comfortable.
    I have looked for a good location and in my opinion to the left of the steering wheel is the best location. There are no displays to the left that would be blocked. It could be put at about the same vertical position as the three displays to the right of the steering wheel. That is only slightly lower than the view of the road ahead.
  13. Nate the Skate
    Nate the Skate New Member
    27
    Houston, TX
    2014 Prius c
    I'm bumping this up as I'm struggling trying to find the best solution. The vent mounted holders work - but block airflow during a Houston summer.
    Dash mounted suction devices don't seem to hold well with the texture of dash material.
    I tried a 3 USB mount that plugs into lighter slot, but it's rubberized, doesn't make a good electrical connection, and with the weight of my Samsung S7, just cannot hold the connection.
    I was wanting to avoid a windshield mount but I'm running out of ideas .
  14. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    This is what I've got. *Note: not mine in the picture, just a quick one from google.
  15. Nate the Skate
    27
    Houston, TX
    2014 Prius c
    Thanks for suggestion ztanos I ended up getting an Iottie One touch, mounted on side window, extends slightly above drivers side A/C vent. 20180718_134144.jpg
    LnG likes this.
