Salvage yard battery
Discussion in 'Generation 1 Prius Discussion' started by Pris2002gen2R, Jul 15, 2018.
  1. Pris2002gen2R
    Pris2002gen2R New Member
    Fresno,California 93619
    2002 Prius
    Need help computer does not like battery pack me and my brother put together,it is a gen 1 upgraded to a gen2 pack,any ideas most appreciated.The best time is about 3 hrs before it kicks codes,I can usually unhooked the battery to reset the car,
    WHEN WE got the car a year ago it had been sitting a year,then six months before we got it up and running $1,800 later and 40 hrs later she runs,been driving for about a month,love the car only had to call my brother for a jump once after a short test drive,started right up and have not had to jump since,new Wal-Mart battery IBelieve,Never left me stranded since,someone mess with ingintion switch never got both screws tight might have to try and tighten again,starts and runs after reset for about 10 miles,battery on screen goes halfway than full that is usually the time the red triangle and check engine lite comes on,Sometimes I can turn of 10 seconds and resets,Sometimes I have to disconnect the battery,
    WHEN it gets hot the abs,brake light comes on and you can here a scraping noise coming from the engine compartment.I Belive that is all my problems for now?Any advice will help,over 40 years turning a wrench but this is new to me,had a lot of old cars out of necessary,this is the newest car I have ever own,SAD but true and I still love my Prius
    Old saying if you do not like a prius you have Never own one are you have lots of money for gas!!!
    Thanks in advance for any help Richard.if this is wrong place tell me where I need to put it?
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    It would help if you pulled the codes and posted them. Your best shot is to get a mini vci cable & Techstream software--it's the pirated version of the Toyota software and will show the codes, HV battery condition, etc. Cheap on Amazon & Ebay. Also if you're needing jumps on the little battery in back, you probably have a bad battery or a parasitic drain.
    When you reset, you also reset the readiness monitors. When those turn back on, your codes are detected & set. Really no good alternative to getting the problems fixed.
  3. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    You should get a set of service manuals. You can find them on Ebay, any set for 01 to 03 will do. Rockauto carries BISHKO 10503 BOUND for $100 both of the major manuals, they are factory reprints. If you get stuck, the bay area is a great place for indy Prius garages--look up Luscious Garage. Probably spendy, but they sure do know their stuff.
