lavatory faucet install ?
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Jul 14, 2018.
  1. cyberpriusII
    1,157
    1,833
    Hyampom
    As a bit of a strange gift we were given a new bathroom vanity and vanity top. Installed.
    That did not include the faucet or the water lines or drain.
    My mobility is not what it was and my husband, who is 6-foot plus, plus, plus has been trying to install the new faucet today.
    It's a "single-hole" Delta. The problem is, he has gotten the under sink flange as tight it can go and the faucet atop the marble countertop still moves about.
    The space is extremely tight for him and he has given up for the day. Poking about the web, the only thing I saw was trying some emery cloth between the under sink flange and the countertop.
    But, that does not make sense, since the under-sink metal part is not moving, it is the atop sink faucet that is moving.
    Sunday is a new day and he is determined to get it right by afternoon. Any tips?
    In the following video, you will see the problem part starting at the 46-second spot....
    The part is about as tight as it goes with the "included wrench>"
    I was thinking old bike inner tube between the undersink flange and the bottom of the countertop, but again, it is the top part (faucet) that is moving?
    delta bathroom faucet install - Google Search
    #1 cyberpriusII, Jul 14, 2018
  2. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Might be easier to remove the vanity top (if it can be removed) and then install the faucet/water lines with the top off, then reinstall it.
    Oops, I should have finished reading your post. I watched the video so I am now up to speed. ;)
    You might try the bicycle tube trick between the faucet and the countertop.
  3. bisco
    52,355
    yeah, flip it upside down if you can get it off. is there a gasket on top under the flange?
    does it have the metal flange you put on before the nut, as shown in the video?
  4. cyberpriusII
    1,157
    1,833
    Hyampom
    Countertop does not come off without a sledgehammer.
    The flange is pretty much as it looks in the video (well, it is actually a different design, but the concept is the same) -- it actually looks like the part below -- #4.
    I found one post that said it is a common problem (no solution) and one "help" forum answer from Delta about the emery cloth. And a third post from Delta telling folks to use Silicone to stop from moving, which is a real stupid solution as silicone will not stand up to any sort of torque.
    As you can see in the instructions below, part #4 is the part that snugs up under the countertop, held by the nut # 6. Parts 2&3 are the parts on the bottom of the faucet that snug to the top of the countertop. Part 2 is a decorative metal ring. Part 3 is a plastic ring/gasket. Part 5 is the threaded rod that the nut (part 6) threads onto.
    And, yes, the faucet is extremely ugly. I was not having my best day when I picked it.
    #4 cyberpriusII, Jul 14, 2018
    pilotgrrl and Stevewoods like this.
  5. Stevewoods
    Stevewoods Senior Member
    663
    1,199
    Seattle, WA
    First, I think there should have been more "parts" in your kit.
    Not your fault, just the "default" today.
    I am wondering if an o-ring or a flat washer the same diameter of that plastic ring would solve the problem. Either remove the plastic gasket altogether, or place the rubber/o-ring under it. You could still silicone it, just for giggles, but I do not think it would be needed.
    I just checked the single-hole faucet on my kitchen granite countertop and there does not appear to be any sort of gasket under it (up top). It, of course, was installed by a journeyman plumber....
    pilotgrrl and cyberpriusII like this.
  6. cyberpriusII
    1,157
    1,833
    Hyampom
    Thanks for the replies.
    Still without a working faucet. Husband ran into work problems overnight and ended up going into the office and then coming back home and sleeping the afternoon away.
    Any tips are still appreciated.
    kris
  7. bisco
    52,355
    is the problem that the nut threads all the way to the end, but the countertop plus #4 aren't thick enough?
  8. bisco
    52,355
    just a thought, is the faucet lowes or home depot? maybe return for a working design.
  9. cyberpriusII
    1,157
    1,833
    Hyampom
    Bisco:
    I am challenged on movement lately. Husband is still asleep. Not sure what is going on with the amount of tightening left. I found that Ridgid makes a new sort of basin wrench that I would not mind owningl
    We will have to see....I suspect this will be a week of "yeek" and then a simple solution in the end.
    kris
  10. ChapmanF
    18,512
    I have sworn at a single-hole Delta like that myself. The base is ... round. Sitting in a round hole in the sink. And secured by one attachment, the nut over that one, round, threaded nipple. Pretty much nothing in the design to stop the whole faucet body from turning in the hole.
    Now I'm trying to remember what I ultimately did with that thing. I seem to recall noticing that somewhere at the base it had a flat spot or a notch, and I might have fabricated something that engaged with that, and was big enough to lie snugly against the back of the sink so it couldn't spin, with a hole drilled through it for that threaded nipple, and used it instead of the stock item ④.
    Even if that isn't what I did then, it might be what I'd do now. Nylon and HDPE are both nice easy-to-machine non-corroding materials, and you can just go to a housewares aisle and pick up a ½" thick HDPE cutting board and use it for years of little scroll-saw projects....
    -Chap
    cyberpriusII likes this.
  11. bwilson4web
    16,352
    Duct tape is like the force. It has a light side and dark side and holds the universe together.
    pilotgrrl likes this.
  12. Mark57
    2,945
    2,740
    OK
    Plumber's putty. Seals cracks of all kinds, except the one behind the plumber . . . . .
  13. tochatihu
    tochatihu Senior Member
    9,851
    3,813
    Kunming Yunnan China
    2001 Prius
    With apologies to OP, wiggly faucet is clearly a first-world problem.
  14. cyberpriusII
    1,157
    1,833
    Hyampom
    Husband Kevin ended up with the afternoon off. He tackled the faucet from H*** again. This time with thin rubber washers/gaskets both above and below the sink.
    Success. No movement. However, the vanity top leaks slightly, but is still usable. Those folks will be out to fix that on Tuesday.
    So, 95 percent good!
    Nice, since have been without use of the master bath sink since February.
    Oh, the drain was clogged after we got it all set up also, but a quick run of the closet auger fixed that.
    kristen
  15. bisco
    52,355
    which folks? the vanity top folks? they'll probably tell you it is the gaskets.
  16. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    So, twins?
  17. tochatihu
    9,851
    3,813
    2001 Prius
    Photos or it's not real:)
  18. cyberpriusII
    1,157
    1,833
    Hyampom
    The countertop is cultured marble.
    When we filled the sink to the top to check for drainage and leaks, there were two small drips under the countertop, just under the overflow, which of course was being tested when we filled the sink to the brim.
    so, when crafting, some air bubbles developed just below the overflow on the underside of the sink, which is really hard to see as it crammed up under the vanity.
    The crafters offered to totally replace the top, or to patch the small spots underneath. Patch and it will be done Tuesday. New top and it will be Aug. 9.
    Went for patch. No one ever will see it as I don't think most folks get on the floor of someone's bath, lie on their backs, get a flashlight and stare into the innards of the underside of the sink.
  19. tochatihu
    9,851
    3,813
    2001 Prius
    What, other people don't do that? :oops:
  20. tochatihu
    9,851
    3,813
    2001 Prius
    Actually, motivation for first-posted gift is only thing that could elevate this to a miniseries. Whomsoever editorializes on your guest-pooper decor by delivering new hardware?
